E-fan install ?
Old Oct 18, 2010 | 01:13 PM
ralaubach's Avatar
ralaubach
From: If at first you don't succeed... go back and reload!
Default E-fan install ?
Forgive me for my limited electronics knowledge, but I am in the middle of installing my black magic fan that i ordered from moes. If i do not wire the fan to a positive ignition source, the fan will continue to run when i turn the vehicle off. But it will only run untill the temp is below my desired setting correct...?
I suppose what I am asking is, do i need to have it wire to a positive ignition source or is the positive wire off the battery fine?
Old Oct 18, 2010 | 01:56 PM
Rich 2500's Avatar
Rich 2500
Forgive me for my limited electronics knowledge, but I am in the middle of installing my black magic fan that i ordered from Mose. If i do not wire the fan to a positive ignition source, the fan will continue to run when i turn the vehicle off. But it will only run until the temp is below my desired setting correct...?
That is correct.
Off the battery is fine, if you do not mind it running with the key off. I prefer it this way, it allows you to shut the engine down and still continue cooling, handy if you tow heavy, race, or anything else where you would want to prevent heat-soak.
Old Oct 18, 2010 | 03:42 PM
HammerZ71's Avatar
HammerZ71
That is actually the RIGHT way to do it.
I din't, but I'm also running a 180* thermostat, so if my engine temp creeps up a little bit after shutting the engine down, no biggie, I still won't go up much past the 195* it would be with the stock t-stat. So I went with a switched power source. I guess I'm paranoid about the thing coming on and draining my battery, LOL...
Old Oct 18, 2010 | 05:21 PM
dirtydog's Avatar
dirtydog
Moderate User
Stock clutch fan only spins with the engine running, so you'll be fine to run it with the ignition source so it turns off with the ignition.
Old Oct 18, 2010 | 05:29 PM
HammerZ71's Avatar
HammerZ71
This is true, I originally wired mine "by the book", but I would never go inside until AFTER I heard my fan shut off. Usually did so in about 1-2 mins, but I got tired of gettin' skeeter bit in the evenings waiting till I heard my fan shut off...
Old Oct 18, 2010 | 05:46 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Mine runs after the key is off but with having two batteries, i dont think it will kill mine easily....LOL
Old Oct 18, 2010 | 05:52 PM
MikeHTally's Avatar
MikeHTally
Mine switches off when I shut the motor off. Cooling systems were designed for that. The fan draws so much current, you pretty much have to go to the battery for fan juice. You can use a switched hot for the low-current side if you want.
Old Oct 18, 2010 | 06:28 PM
HammerZ71's Avatar
HammerZ71
I don't think amp draw is gonna be an issue for the OP. MY 180 Extreme only draws 18 amps and if I'm not mistaken, the Black Magic he has is somewhere down around 12 amps...
Old Oct 19, 2010 | 01:26 PM
Rich 2500's Avatar
Rich 2500
Yeah, I've been running mine, "un-switched", for over two years now without any battery issues, but I have to admit I was skeptical for the first month or so.
