Old Aug 14, 2015, 02:43 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
Mopar 4" lift Kit
Old Sep 3, 2009 | 03:20 PM
  #21
jake09's Avatar
jake09
i 2nd the post on more pics....would love to see some more of the blue truck
Old Sep 6, 2009 | 12:08 AM
  #22
carbonjuicd's Avatar
carbonjuicd
bump. picks
Old Sep 6, 2009 | 02:21 PM
  #23
Monsoon's Avatar
Monsoon
Originally Posted by mbaseball3
couldn't help but notice the helicopter in the pics which led me to question, does the helo come with the lift?
Mopar is running a special on the 4" lift. $2 million for the lift and they throw in a free helicopter.
Old Aug 29, 2010 | 10:29 AM
  #24
alberta1's Avatar
alberta1
Default 35" tires will make ECO/MDS to never kicks in????
After reading many threads on installing 35" tires, it seams that the ECO/MDS will never kick in With any of the stock gearing. even 3.92
What's the real MPG for this truck and can this be corrected to get the ECO to kick in?
Thanks
Old Aug 29, 2010 | 02:04 PM
  #25
frogslinger's Avatar
frogslinger
Originally Posted by cpelton
Remember warranty only affects the parts you changed out. Superlift has a warranty on those parts so you do not really lose any warranty you just have to go through them to have any suspension parts replaced should they fail. But No, if you buy the mopar lift and have a dealer install it you will not lose any warranty, but be prepared to spend twice as much.
The first part of that is not true... for example if you buy a K&N filter and it is over oiled and that frags your MAF then the MAF repair is not covered under warranty. If buy HIDs and they melt the housings and burn out the headlight wiring, those parts are not covered by the warranty. If you put in an aftermarket rear diff and it fails causing your rear end to lockup, causing you to slide into the median, flip over and total the truck, none of that is going to be covered by the warranty...
In other words incidental and consequential damage to your vehicle from aftermarket parts falls on the owner...
That said this does not apply in this case as it is a "Mopar" kit.
Old Aug 29, 2010 | 02:53 PM
  #26
Doc Fluty's Avatar
Doc Fluty
^^^ true
Old Aug 30, 2010 | 11:05 PM
  #27
DIVERMAN's Avatar
DIVERMAN
Cpleton-- did you use spacers to keep the stock rims? thanks.
Old Aug 31, 2010 | 12:28 PM
  #28
cpelton's Avatar
cpelton
Diverman - Yup, 1/4" spacers in the front.
Old Sep 1, 2010 | 04:10 PM
  #29
DIVERMAN's Avatar
DIVERMAN
thanks, any problems with them? never used them before, and want to keep my stock rims when i level the truck.
Old Sep 2, 2010 | 06:21 PM
  #30
jake09's Avatar
jake09
i have the same lift as cpelton and run 1/4 spacers on all 4 wheels with no problems.
