Keep 05 1500 or buy 12 2500
Old Feb 17, 2012 | 10:39 AM
NoMoreGMsForMe's Avatar
NoMoreGMsForMe
Know matter how much money you put into your 05 to bring it up to spec the problem is it is still an 05 and the book value would probably be less than what you put into it,IMO consider the 012, Good Luck with your decision.
Old Feb 17, 2012 | 11:50 AM
Pedro Dog's Avatar
Pedro Dog
Originally Posted by Phil
The max trailer weight is 7600 #'s, max tongue weight is 1250#. Unloaded I am at about 5000 and 740. I do not know the weight of the wood I load up.
If I trade I will loose 3k on the trade. I will have 8k +/- 2k for fixing or replacing. I am just concerned the 1500 will not hold up.
I already have the 3.92. with the 4X4 I can only go up to 4.10. Not much difference for the cost. I do have the 20" wheels, unfortunately.
If $ is not a problem then get the new truck. I think you can make your truck work though. If the engine and trans have been reliable, you still have some miles left on the truck. You can put on 17" wheels when towing and keep the 3.92. You can load up some of firewood in trash cans and put them in the trailer if you run with the water tanks almost empty. Oak firewood is about 3500#s for red and about 4200#s for white per cord. Your probably putting in about 1/4 cord in the bed.
I can relate with you on towing with a marginal truck trailer combo. It's no fun at all and scary at times, especially on hilly drives. Good luck.
Old Feb 17, 2012 | 09:25 PM
White2500's Avatar
White2500
Get the new one! Luck will be you dump all that $ in the 1500 than your tranny will go! Or more. Thr new one will do the job you need no problem plus the warranty!.
Good luck
