android phone? Good news!
Old Apr 5, 2012 | 03:47 PM
Nate769's Avatar
Nate769
Originally Posted by Trendkill
Wait, you can stream Pandora over Uconnect via bluetooth?
I just recently got my Uconnect to accept my Android phone. I had to go into uconnect and wipe out the old phone completely and pair everything up again. Before I did that, it was trying to import my phonebook and would make this nasty sound like your pc makes when it crashes hard.
Anyway, gonna have to give this a try. I've been using the aux input cable for it, but streaming via bluetooth would be much cleaner and less trouble.
I think you would be much better to use the aux cable...bluetooth is/was very slow and jumpy. I could be wrong, but I like the quality out of my music. Everything I do is direct from the hard drive...
Old Apr 5, 2012 | 05:08 PM
Talon_66's Avatar
Talon_66
Which ICS build are you on?
Old Apr 5, 2012 | 05:26 PM
BigBlueEdge's Avatar
BigBlueEdge
I don't think BT streaming is a feature on the pre-2011 models. I have an RBZ (430) from late build 2010 and I've never found any reference to that feature.
Rob
Old Apr 5, 2012 | 08:14 PM
Nate769's Avatar
Nate769
Rob
I do believe it is only capable on some phones. I have not tried bluetooth streaming on mine, but it might try it out just for giggles...
Talon I am on build DXLP7...Its an Indonesian version but it is very very stable, and like I said it works flawlessly in my truck! It picks up every call, and it seems that its a little more reactive with the signal strength. Before it seemed that the signal strength was delayed on the previous version...
Old Apr 5, 2012 | 10:27 PM
BigBlueEdge
OK, so has anyone got BT streaming activated on a 2010 radio?
Rob
Old Apr 5, 2012 | 11:23 PM
Nate769's Avatar
Nate769
ya sorry...i keep forgetting mine is a 2011...
Old Apr 6, 2012 | 09:01 AM
Trendkill's Avatar
Trendkill
Try as I might on my 09, I couldn't find a way to do it. Looks like my phone's capable of it, but couldn't find an option within UC to make it happen. Works on my buddy's Tundra though! D'oh!
Old Apr 6, 2012 | 10:00 AM
xsdbs's Avatar
xsdbs
Bluetooth Streaming Audio is only supported by Uconnect from 2011. (actually there were some 2010.5 Rams that had the 2011 UC system because Chrysler had run out of the 2010 radios and had to use 2011 radios and UC). Vehicles prior to that only were able to play the phones media thru cable if it was supported by the phone.
Rob
Rob
Old Apr 6, 2012 | 10:03 AM
xsdbs's Avatar
xsdbs
on the 2011 vehicles that had issues with the "jumpy" or as some called it "sounds like the chipmunks", this was fixed with the TSB 08-036-11 rev A that came out last year. Have you had this applied? I thought that I had helped you with this before. Might just be having a senior moment though.
Old Apr 7, 2012 | 08:23 AM
xsdbs's Avatar
xsdbs
Bluetooth streaming audio will not work on the vehicles built prior to 2011. It wasn't a supported feature till 2011?
What year is the tundra? Not all vehicles support the same features at the same time.
