LSD Question
Old Apr 23, 2012 | 08:42 PM
stimleck's Avatar
stimleck
Default LSD Question
my 2012 3,92 LSD spins both tires on left turns when i gas it but only the inside tire on rights, is that normal?
Old Apr 24, 2012 | 02:28 PM
JonathanA's Avatar
JonathanA
U sure you have the LSD?
It´s not supposed to work that way.
Old Apr 24, 2012 | 02:30 PM
JonathanA's Avatar
JonathanA
You can easily test if you have limited slip. Raise the rear so both wheels are off the ground. Spin one of the tires forward, if the other tire rotates the same direction you have a limited slip, if it rotates the opposite direction you don't!
Good luck!
