lift + levelling kit?
Old Apr 13, 2015 | 06:04 PM
07ramman1500's Avatar
07ramman1500
Default lift + levelling kit?
I got a 2.75 front and 1.25 rough country levelling kit and a 1.25" RC body lift, and I'm thinking about putting a 6" suspension lift in. What would happen if I kept my leveling kit in? Has anyone tried it? I'm thinking it will look off, and the front be higher than the back right?
Old Apr 13, 2015 | 06:08 PM
07ramman1500
Its on a 2012 crew cab **
Old Apr 14, 2015 | 10:34 AM
Arctodus's Avatar
Arctodus
I would say absolutely not! You can install the 6" and leave the body lift on , but that lift is not designed to go along with an additional lift, plus the angles it would put on your drive train components ( front and rear drive shaft, cv shafts etc ) would probably be too much.
Old May 24, 2015 | 09:26 AM
j_h_smith's Avatar
j_h_smith
Remember when you do a body lift, you may have a lot of extending and relocation of things like wiring harnesses, break lines, gas filler hose, and ground straps. It's not as simple as lifting the body off of the frame and slapping the pucks between the 2 and you're finished.
Good luck!
Old May 29, 2015 | 12:43 PM
HammerZ71's Avatar
HammerZ71
You can stack a suspension lift with a body lift but not two suspension lifts.
Old Jun 28, 2015 | 05:16 PM
KasperR34's Avatar
KasperR34
I'm running a 3" level and a 3" body lift and a 6" suspension lift with no problems. My brothers 05 2500 ran a 6" and a 1.5" level
