2015 Dodge Ram 1500 4x4 slt 5.7
Old Jan 10, 2020 | 05:41 PM
Jwhite79's Avatar
Jwhite79
Default 2015 Dodge Ram 1500 4x4 slt 5.7
I know there is a zerk fitting on the stock upper control arm but it's a dummy zerk you can't and grease to. My question is if I put a greasable zerk fitting can I grease them that way?
Last edited by Jwhite79; Jan 10, 2020 at 05:49 PM. Reason: I wanted to add a image.
Old Jan 11, 2020 | 08:37 AM
No. That's not a zerk fitting. Its a ball mount for some option your truck doesn't have. You could put a zerk fitting there, but, all you would accomplish is filling the control arm with grease. (and it would take a LOT.) None of it would make it to the bushing.
Old Jan 11, 2020 | 12:45 PM
primem's Avatar
primem
yep. its the mount for the air suspension ride height sensor. you will do more harm trying to add a grease fitting. When the grease for life part wears out (and that could be a long time) replace it with a greaseable part.
when the grease fittings are present...1/2 the time the lube techs don't grease them anyways. I'm the only one at my shop that has a needle to grease the double cardan joints on the 2500 to 5500..sad
