Old Aug 14, 2015, 07:15 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Towing & Hauling Guides
Print Wikipost
Installed a Mopar receiver hitch
Old May 18, 2009 | 06:57 PM
  #21
Hdcowboy's Avatar
Hdcowboy
Does it install the exact same way as the Curt Manufacturing class 3 hitch(model #1333)? Thats what I put on mine, cost me $87. And you do have room for a socket if you drop the spare tire, I dont have an idea how you can get the bolts to the proper torque specs without using a torque wrench and a socket. Here are the instructions for mounting.......
http://fileresource.sitepro.com/file...C4AD797886.pdf
BTW...The Curt manufacturing Class 4 & 5 hitch (model #14374) is $165
Old May 24, 2009 | 03:27 PM
  #22
Fabman1's Avatar
Fabman1
Anyone w/ a Ram 2500 here ever consider installing a Reese Titan Hitch assembly??
These babies are rated to pull 18000# w/ 2000# tongue weight - no mention of Weight Distribution...
http://www.etrailer.com/pc-H~DT45295...eid=2006203632
Old May 25, 2009 | 01:11 PM
  #23
Parisv's Avatar
Parisv
Wierd. I bought a Curt Class IV Hitch rated for up to 10,000 lbs and it just bolted on. Oddly, this is not available on the Curt website though. The only minor annoyance is that the main bolt that goes through the rear bumper into the hitch protrudes and the stock hole cover will not fit over it. I removed the main bolt and put the cover back and will just pop in the main bolt when I need to tow something. I also may see about finding a flatter head bolt to replace it with.
What's really odd though is that this is a class IV hitch per the packaging and markings, but it does indeed bolt on. Somethings not right...
Here's the link to the auction: http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Old May 25, 2009 | 01:19 PM
  #24
Parisv's Avatar
Parisv
I think I found the difference. Per the instructions:
GROSS LOAD CAPACITY WHEN USED AS A WEIGHT CARRYING HITCH: 6,000 LBS. TRAILER WEIGHT & 600 LBS. TONGUE WEIGHT.
GROSS LOAD CAPACITY WHEN USED AS A WEIGHT DISTRIBUTION HITCH: 10,000 LBS. TRAILER WEIGHT & 1,000 LBS. TONGUE WEIGHT
I'm pretty sure, all Ram's "distribute" the weight across the steel hitch tube that the hitch mounts to. I suppose if it didn't have the stock steel hitch tube to distribute the weight, then it would be only good for 6,000 lbs. I guess that would mean just mounting it to the bumper. I'm calling to call curt to clarify, but that makes sense to me anyway. The weight is definitely distributed across the steel hitch tube though.
Old May 30, 2009 | 11:04 AM
  #25
mrbrown's Avatar
mrbrown
I was also wondering about the weight distribution. I think you've got it right. Know body seems to know the real answer though.
Old May 30, 2009 | 11:25 AM
  #26
oldjeep's Avatar
oldjeep
Uhh - no. A weight distribution hitch is also called a sway contol. It mounts in the receiver and to the sides of the trailer a-arm
http://www.etrailer.com/faq_weightdistribution.aspx
Used with a standard receiver a class 4 hitch is good for 6000lbs
As a note - of the 100 or so Rams that I saw on dealer lots, I didn't see one that didn't already have the factory class 4. Seems silly that it's even an option.
Old May 30, 2009 | 04:21 PM
  #27
Hdcowboy's Avatar
Hdcowboy
Damn those weight distribution hitches dont do anything but confuse me.....
So I take it #1 is supposed to represent the hitch on my truck and #5 is supposed to represent the hitch on the trailer? Does #3 suppose to represent my trailer ball which somehow conects to #2 which slides into the square tube that my ball mount usualy slides in? What would happen if I wanted to rent a trailer? Would I have to go drilling holes in the trailers hitch to mount the dang bracket looking things that the chain and #4 connect to? I dont get it!
Old May 30, 2009 | 05:26 PM
  #28
seigell's Avatar
seigell
Default 09 Ram 1500 Factory Tow Package
Here's a few shots to show the Factory Tow Package ClassIV Receiver.
Receiver viewed from below:
(Note: Receiver is welded, not bolted, to crossmember. 5-6 welds seen)
Receiver viewed from behind:
(Note: Bolts are the center bumper mounts.)
Crossmember - Frame-end mounts.
(Note: There are 6 large bolts - not counting the bumper mounts)
Note: All photos also "star" the "Limited Use Spare" that I am so disappointed over as stock on a 4x4 Truck (big, round, bald, wimpy).
Old May 30, 2009 | 05:35 PM
  #29
seigell's Avatar
seigell
HD: You are right in most all aspects - except #2&#3 replace the familiar hitch (drop-tongue bar and 2" ball). You would use a standard bar and 2" ball for "normal" towing situations without any of this "get-up".
The load distribution system turns your hitch receiver and trailer tongue into a big lever, in order to "distribute the load" across the entire truck frame.
As for towing a large rental trailer - the company that rents anything big enough to recommend a L-D Hitch System should already have all the necessary rig on their trailers. In fact, you should be very suspicious if they aren't concerned that you use a L-D Hitch - it's your safety and your insurance that is at risk as well as their trailer.
Old Jun 1, 2009 | 07:24 PM
  #30
Parisv's Avatar
Parisv
Thanks for clarifying. Now I'm sort of bummed that it isn't a class IV hitch. Not that I need to tow anything that heavy, but if I did it would be nice to know it's there. Oh well...
