Has anyone replaced their grill?
Old Apr 13, 2009 | 03:08 PM
Dr. Bill's Avatar
Dr. Bill
You can buy the black honeycomb or the horizontal bar from OEM dealers. I can life with the chrome grille, but I think the chrome inserts look like crap. I have a yellow sport so I am not sure if they even make a yellow grille anymore.
Old Apr 13, 2009 | 03:45 PM
turk1270's Avatar
turk1270
if anybody doesnt like their chrome honeycomb grille inserts send me a pm i would like to buy a set.my truck has the billet and i think i would prefer the honeycomb
Old Apr 13, 2009 | 04:35 PM
mopowar's Avatar
mopowar
Originally Posted by 94rt10ohio
This may be the way to go, that is if the whole thing was $307 with paint.
What did the $307 include? All new mesh and cross hairs? Or was that new mesh and paint your old cross hairs?
Mine came painted. They asked for the vin (I don't know why) to get the color match. Maybe the colors change slightly through the production cycle?
Call here:
http://www.hensonmotor.com/index.htm.....talk
and ask for Art. Ordered on Wed. arrived on Fri.
Old Apr 13, 2009 | 04:52 PM
mopowar's Avatar
mopowar
So....
I was going to give you a deal, but looking at my old grill this thing seems to be put
together in a fashion to where either part is integral to the other. On the top, it is actually the inserts that bolt down, and the grille is clipped on to them. On the bottom, the grille clips in, and the inserts are clipped to it. The inserts have hard plastic straps that run between them, so basically there is one solid piece that is the inserts, and another that is the grille. No more making your own inserts with mesh from Home Depot
Old Apr 13, 2009 | 05:49 PM
Dr. Bill's Avatar
Dr. Bill
This grille is not as simple as the 3rd gen. Can you change the inserts without removing the grille?
Old Apr 13, 2009 | 07:14 PM
CarGuyOhio's Avatar
CarGuyOhio
Call here:
Parts people are not what they use to be. Good ones do not need the VIN, the ones who know less need the VIN to make sure they are correct.
For $300 you get a whole new setup. Then someone somewhere will want to change to chrome, so I could sell my old one, which will be vitually new for $150-$200. Becomes a no brainer at that point.
Old Apr 13, 2009 | 07:25 PM
mopowar's Avatar
mopowar
"This grille is not as simple as the 3rd gen. Can you change the inserts without removing the grille?"
No. I had a 2nd gen.,and that was checkers compared to this. There is a black plastic crossmember that is attached (molded to) to the two upper inserts. Four extrusions from the same crossmember are where the upper portion of the grille assembly attaches to the radiator framework. The two upper inserts are attached by six plastic straps (three each, hard molded) to the lower inserts. The lower inserts simply clip to the outer grille cover (the cross), and then two small bimetallic clips which are attached to the lower back corners of the outer grille hold the assembly in place at the bottom. Either one (inserts or the grille) is no good without the other.
Old Apr 13, 2009 | 07:30 PM
mopowar's Avatar
mopowar
Parts people are not what they use to be. Good ones do not need the VIN, the ones who know less need to VIN to make sure they are correct.
I just found the Invoice. I paid $239.16 shipped for the Deep water blue from the dealership that I posted up.
Old Apr 13, 2009 | 07:40 PM
CarGuyOhio's Avatar
CarGuyOhio
When my truck comes in and I pick it up I will try to get the grill for free or at least a discount on it. So maybe it will be the first day of ownership
For the one looking for a chrome one, I will have one in about 8 weeks.
Old Apr 13, 2009 | 09:22 PM
sarguy01's Avatar
sarguy01
You can always cut the grill to add Home Depot mesh, right?
