Oil Change Message Info
Old Apr 17, 2009 | 09:40 AM
  #21
Big_Fishman's Avatar
Big_Fishman
Originally Posted by LoneStarStro
Not trying to hijack this thread but you mentioned the setup option in the EVIC and I realized that I have a lock symbol next to mine. Is anyone else locked out of their setup?
Originally Posted by 72combo
I should not even post this but, mine was locked too and well I did something and the lock dissappeared so now I am into everything. I have to get out there and see what all and if it is locked again. I was at UPS and playing with it while my wife was in there, so we didn't have time to play. When I got home I have to get out and do some stuff. I don't plan on going anywhere with it right away, driving my 72 chevy right now. Since I cannot get into the truck very easy.
The lock should disappear when it is in park and reappear when you are driving.
Old Apr 17, 2009 | 03:11 PM
  #22
Smoothbassman's Avatar
Smoothbassman
Originally Posted by v8440
I think the way it works is in between a "dumb" message based only on miles traveled and a sophisticated system that actually measures things in the oil. If it's like my '08 honda civic was, it was based on an algorithm that estimated oil life based on a number of factors monitored since the last oil change. I think the average distance traveled PER TRIP since the last oil change was one of them, as well as oil temperatures, outside temperature, speeds traveled, etc. These things are easily monitored by modern engine management systems, and can be used to calculate a pretty accurate estimate of oil life.
I would have to agree.
I changed mine for the 1st time with 4200 miles on the truck with Full Synthetic Oil. I now have 12,000 on it and the light just came on. Pretty good life 7,800 miles on Synthetic. Most of my driving was on the highway and about 20% was towing or hauling some of my toys around to different spots.
Old Apr 18, 2009 | 01:02 AM
  #23
72combo's Avatar
72combo
Now my 09 says you have to use a oil with detergent in it and I did not think that Synthetic had that? And it also mentions a pretty watery oil 5W 20 Anyway I have dedided since I took it to the dealer cuz the running boards were rattling. I could fix it but why should I. Well they said nothing they can do, it's the design. I said you can't put some rubber were it's rattling. They said its the design, I said then give me some that are designed right. They are working on it. In the mean time I had my bro inlaw get under there with a couple pieces of thin rubber and I pushed on them and he put the rubber in the spot where it was rattling. Fixed for now LOL, if it's not in the manual they can't fix it........so no more dealer for me. Sorry guys I know it helps keep you in business but hell you don't even rotate tires as per the recommended pattern, when I question it they say that is the way we do it.......ya in the 70's when radials would fall apart if put on the opposite side.
Old Apr 18, 2009 | 01:51 AM
  #24
Blackzilla's Avatar
Blackzilla
2700+ miles no message yet.
