Oil change and K&N drop in
Old Apr 22, 2009 | 07:26 PM
RamAirman's Avatar
RamAirman
Default Oil change and K&N drop in
I just did my first oil change (M1 5W-20, K&N filter) and replaced the OEM air filter with the K&N drop in. I'll update if I notice a difference from the air filter. I jacked up and checked the oil without starting the truck and it was low so I added an extra quart the started the truck and checked and now it's over. I'm a genius!
Old Apr 22, 2009 | 08:06 PM
allhans's Avatar
allhans
I did the exact same maintenance a few weeks ago. The filter make a moderate difference.
Old Apr 22, 2009 | 08:09 PM
RamAirman's Avatar
RamAirman
Just curious, since I put too much oil in, is that going to be bad on the crankshaft? Should I drain a bit of it?
Old Apr 22, 2009 | 08:31 PM
blue2050's Avatar
blue2050
Depends on how much overfull. Even a little overfill adds pressure to your front and rear seals. Overfill enough where the crankshaft is hitting the oil causing a foaming effect and your pressure will drop. Check engine light will come on. Over full causing this foaming will not lubricate properly and prematurley burn the engine up.
general rule.
"Do not overfill" as it says on the dip stick.
Drain some out..
Cheers
Blue
SubRammer's Avatar
SubRammer
You should definitely drain it back to the safe level. If your oil level is above the safe line it can mean that it is near or at the the level of your crankshaft. This won't hurt the crank, but if the crank is within reach of the oil the rotation of the crank in the oil will cause your oil to become aerated which in turn makes it difficult if not impossible for the oil pump to pump the oil through your system. While your oil level on level ground may not reach the crank, it may reach it when you are on an incline.
Old Apr 22, 2009 | 08:32 PM
MinatorHemi8's Avatar
MinatorHemi8
7 quarts means seven quarts.
and dont try convincing anyone here it gives you any gains, I did the same thing and felt a lot of pick up in the end but I was then told it was a placebo
Old Apr 22, 2009 | 08:47 PM
RamAirman's Avatar
RamAirman
I only used 6!
Old Apr 22, 2009 | 09:35 PM
Mpd224's Avatar
Mpd224
If you end up having to drain some of the oil, I bet you wish you would've had this. http://www.quickoildrainvalve.com/ I've put one on all of my vehicles and I wouldn't go without it.
Old Apr 23, 2009 | 02:05 PM
Soop's Avatar
Soop
This is cool. I had something similar to this on my Rubicon but this is better...thank!
Old Apr 23, 2009 | 02:16 PM
spoon's Avatar
spoon
The F-101 with nipple?
