Adding One Touch "Up/Down"
Old Apr 23, 2009 | 11:13 PM
sykoball's Avatar
sykoball
Lightbulb Adding One Touch "Up/Down"
Was thinking about adding this feature to the back sliding glass. Found this module on the Autoloc website. http://www.thehoffmangroup.com/autol...netouchwindows
Not sure of how that switch is wired (if it's a 5 wire), haven't had a chance to figure out how to take the overhead console apart to see how its wired, or if there is any room up there for the module, any thoughts??
Old Apr 23, 2009 | 11:19 PM
Inbred's Avatar
Inbred
I don't know about that switch in particular, but the other window switches are signal wire/resistor setups. Ground the signal wire through one resistor value tells computer to open window, ground through another value resistor, computer closes the window. A third value resistor triggers autodown on the conventional windows.
I would assume the rear glass works the same way, since there is no auto open, you would need to do some improvising, including dissecting the switch to determine the resistance values for open/close
Old Apr 23, 2009 | 11:32 PM
sykoball's Avatar
sykoball
Default Hmmmm....
Well, I guess I know what I am doing on sunday! Try and figure out how that switch is wired. Will post an update with my findings. If it is wired the same as the other window switches, any idea on how to make it work.
