1/4 mile time
Old Apr 30, 2009 | 11:43 PM
MMMMRice's Avatar
MMMMRice
Originally Posted by socaliallstar82
where did u get that 13.8 time from bounty? I know your not running faster than v8440
Hes full of ****, he pulled the time out of his ***.
On a side note, do I have the worlds heaviest rcsb? With a full tank and me it sits at 5500lbs. WTF!!
I ran a 14.9 without using 2nd prime/full weight with no cool down/ 3.55s and 1/4 tank of gas. So Id say with 3.92s, cool down and second prime you have a shot.
Old Apr 30, 2009 | 11:57 PM
socaliallstar82's Avatar
socaliallstar82
How many miles do you have on your truck? That may have something to do with it. A little break in may help out.
Old May 1, 2009 | 06:53 AM
v8440's Avatar
v8440
Originally Posted by Superdodge33
im familar with the track and how to race, just curious on what i will pull with this truck. that starting in 2nd gear thing works?
The truck does not actually start in 2nd gear. Before you stage, select 2nd manually. The truck will leave in 1st and automatically shift into 2nd. Then you have to start shifting manually after that. When you're at the top of 2nd gear and you select 3rd, it will actually go into 2nd prime. Just a second or two in 2nd prime and you'll be selecting 4th, which is really 3rd. I think you'll be finishing your pass in that gear. If you simply select 3rd or 4th from the start, the truck will NOT shift into 2nd prime at all, but will shift to actual 3rd gear instead. You must actually manually shift it into 2nd prime (3rd on the gear display) to get that gear-having it in manual mode but limited to a higher gear is not enough.
Old May 1, 2009 | 08:23 AM
MMMMRice's Avatar
MMMMRice
I cant wait to get back to the track to try that. How much quicker do you think that will make me?
Old May 1, 2009 | 09:57 AM
Superdodge33's Avatar
Superdodge33
Thanks V8840.
What RPM am I shifting at on these 2009's? 5300? Oh and should I bring Bring Rpm up to launch? If so how high should I bring it on the launch?
Old May 1, 2009 | 10:07 AM
v8440's Avatar
v8440
I'm guessing it will make a tenth or two, probably no more than that.
As for launch, I find that running it up against the converter hard is NOT the way to do it. My truck gets it's best short times by quickly and smoothly flooring it from just off idle. Basically, I don't do much more than take the slack out of the drivetrain, then I quickly (but not instantly) floor it. I get good weight transfer that way, and it usually doesn't blow the tires away. My best short time was a 2.10, average is 2.15 to 2.20.
As for shifting, you want to shift as close to 5600 as you can w/o hitting the rev limiter. There is a delay between when you command the shift and when it actually shifts-that is something you have to learn yourself so that you can end up with it shifting when you want it to. As a hint, shifting one or two hundred rpm too early will not hurt your time as much as waiting a bit too late. Spot on 5600 is best, but if you make a mistake it's better to be a tad too early.
Old May 1, 2009 | 10:46 AM
Superdodge33
Thanks for the tips V8440. Im used to racing mustangs so this truck thing is a change.
What model truck do you have and what mods?
What did you run at the track?
Old May 1, 2009 | 11:28 AM
v8440's Avatar
v8440
I have an '09 rcsb 2wd hemi with 3.92's. My best time was a 14.007 at 96.75 mph. The best time I have video of is a 14.13. The truck is as it came from the dealer. No weight taken out, nothing done to the truck that would make it faster.
Old May 1, 2009 | 11:31 AM
Superdodge33
V8440 can i get a link to that video? I think the reg cab is like 400 pounds lighter than the crew right?
Old May 1, 2009 | 11:54 AM
v8440's Avatar
v8440
I dunno, the video is floating around here somewhere. It might be a couple of pages down, in this section.
