4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
never seen a liner for a rambox? have been looking and talking about spray in , but don'y know if divider will still work ?
the divider may not in fact work after LINEX is installed .. thats why i was looking for a drop in liner .. i assumed dodge made them to work with the divider ..
Also local LINEX installers want $500 !!! to spray in liner ! its 30 % smaller than most boxes ! ... you would think they would discount for the smaller square footage but no ....
PRICEY .. phew !
The prep takes longer on the rambox...more surface area because of the divider slots, hardware to remove...etc. My speedliner was $450.
Reason: Added quote and content
I was thinking spray in, but am also considering the Bed Rug or drop-in that is made by the same company, but is similar to a spray in in some respects.
The only drop-ins that I've seen ended up with enough dust / grit / moisture under the plastic that after 3-4 years parts of the bed looked like abused without any liner. The spray-in liner is going to be permanent - never goint to try to remove it. So, for me the spray-in is "no-brainer".
