Quick Tire Question
Old May 6, 2009 | 03:22 PM
c0mf0rt's Avatar
c0mf0rt
Exclamation Quick Tire Question
Yes I'm working a million angles. Will a 255/75/17 tire fit on a 17x9 rim?
Old May 6, 2009 | 03:27 PM
HEMICrew's Avatar
HEMICrew
Rim width range is between 6.5-8.5in on a 255/75/17 sized tire. That's just a simple answer but you need to know backspacing, etc.
Jason
Old May 6, 2009 | 03:29 PM
c0mf0rt's Avatar
c0mf0rt
The Rim is 17x9 with 4 1/2" backspacing.
Old May 6, 2009 | 03:31 PM
HEMICrew's Avatar
HEMICrew
You might need to fit and see. The wheels you want to put on those tires are a little wider than the recommended range so you'd have to check the look and fitment once you mount them.
Jason
Old May 6, 2009 | 03:35 PM
c0mf0rt's Avatar
c0mf0rt
Crap.... buying both online.... guess I'll have to pass up the awesome deal for just a good one then. (on another size)....
So I'm guessing a 265/70/17 wouldn't fit either then huh?
Old May 6, 2009 | 03:39 PM
HEMICrew's Avatar
HEMICrew
265/70/17 WOULD fit your 9" Rim. Rim range is between 7-9in. If you want to keep comparing sizes to see the ranges go here:
1010tires.com and click on the Tire Size Calculator
Old May 6, 2009 | 03:43 PM
c0mf0rt's Avatar
c0mf0rt
Thanks man.
