Offset / Backspacing Help
Old May 7, 2009 | 10:18 PM
c0mf0rt's Avatar
c0mf0rt
Default Offset / Backspacing Help
So which one of these push the rim out and away from the truck? I've found two wheels with the same backspacing but a different offset.
Old May 7, 2009 | 10:43 PM
bountyhunter's Avatar
bountyhunter
Offset - centerline to mounting surface
Backspacing - mounting surface to rim edge
Old May 8, 2009 | 07:31 AM
depunz's Avatar
depunz
Default offset
Negative offset pushes the rims out. My rims have -12 offset and 4-1/2" Backspacing and they stick out about a 1/2" compared to stock.
Old May 8, 2009 | 07:55 AM
switchblade906's Avatar
switchblade906
The stock rims are +20 offset, so anything less then that is going to push the rims farther out.
so from going from a +20 to a -12 you are pushing the rim out 32mm
Old May 8, 2009 | 09:48 AM
nolimits's Avatar
nolimits
The wheel width needs to be taken into consideration, too. A wider wheel with stock offset will stick out more. Add offset to move the wheel in, subtract to move out.
Old May 8, 2009 | 09:50 AM
switchblade906
^^True, i was using the stock 9in wheel width.
Old May 9, 2009 | 11:28 PM
bigblack450's Avatar
bigblack450
so i got a +18 offset with 20inch kmc wheels with 35inch nitto mudgrapplers, 6 inch bds lift. just wondering if the wheels and tires will work. they havent came in yet
Old May 10, 2009 | 11:50 AM
MOPWR2U's Avatar
MOPWR2U
I don't think they'll work. BDS requires 5" or less backspacing with their lift. Your wheels have 5.7" backspacing, and stock wheels are 5.75" backspacing. Hate to rain on your parade, but its BDS's fault, they designed the lift for wheels with less backspacing.
