Is this normal?
Old May 15, 2009 | 04:24 PM
cicdude's Avatar
cicdude
Default Is this normal?
When I am cruising down the road doing say 25-35 mph, and I let off the gas to slow down or as I start to go downhill, the engine will quickly rev up about 50 rpm or so before it drops down. At first I thought I might be pressing slightly on the pedal before I let up, but I'm paying attention and I'm not, I'm just letting up on the pedal.
Old May 15, 2009 | 04:31 PM
bigred3297's Avatar
bigred3297
the truck will downshift on deceleration, this is most likely what it is, this extends brake life
Old May 15, 2009 | 06:16 PM
cicdude's Avatar
cicdude
I don't think it is downshifting at this point, it should not downshift until the speed drops enough. It does it each and every time I let off the gas pedal. This is just a quick 50-60 rpm or show jump.
Old May 15, 2009 | 06:39 PM
budlyte's Avatar
budlyte
Could it be the other 4 cylinders kicking in? I notice my truck usually goes into fuel saver mode as I let off the gas and begin decelerating/coasting, but once my speed gets low enough, the fuel saver mode turns off and I'm back to running on all 8.
Old May 15, 2009 | 07:30 PM
cicdude's Avatar
cicdude
I don't know. I have a December build with the locking tailgate, but missing the MDS light.
Old May 15, 2009 | 08:25 PM
CarGuyOhio's Avatar
CarGuyOhio
I have noticed with MDS kicks in my RPMs drop 50, so, good guess, MDS is turning off.
Old May 15, 2009 | 08:50 PM
GSDMan's Avatar
GSDMan
Yes, it's normal. If I'm not mistaken I believe you are seeing the torque converter unlocking.
G
Old May 16, 2009 | 04:03 PM
cicdude's Avatar
cicdude
G
I was just at service getting some Rapid Response items done, and this is what he said as soon as I asked the question. Thanks.
