What size power inverter
Old Jun 3, 2009 | 01:17 PM
  #31
Sobomaster's Avatar
Sobomaster
All I know is my stock inverter runs my laptop, camera charger, etc. just fine. I even keep an extension cord in the truck so the backseat passengers can plug in if need be. Great for road trips.
If you're planning on running heavier duty items than a generator is probably your best bet. Sams and Costco have some decent deals.
The 2500 used to come with a work truck package that had an under the hood generator in it I believe. That may have been what you saw at the construction site?
Old Jun 3, 2009 | 01:21 PM
  #32
BubbaRadioNetwork's Avatar
BubbaRadioNetwork
I thought there was also a plug on the back of the console for rear seat passengers?
Old Jun 3, 2009 | 01:23 PM
  #33
Doc Fluty's Avatar
Doc Fluty
i think thats just a cigarette lighter plug in the back
Old Jun 3, 2009 | 01:34 PM
  #34
John Valdes's Avatar
John Valdes
Originally Posted by oldjeep
12.5amps is the load that the battery/alternator sees, not how much current it provides on the 115/120VAC side.
My bad. I was using 12 volts not 120 volts in my post and calculation. 120 volts divided by 150 watts is 1.25 amp. My mistake.
