What size power inverter
Old Jun 1, 2009 | 08:14 PM
Doc Fluty's Avatar
Doc Fluty
Originally Posted by oldjeep
And I've had some laptops that will run off an invertor and some that won't. Also had some power tools that wouldn't. My F150 had a 2000W invertor under the hood that we used when camping, and we always made sure to check stuff before bringing it along.
i used my laptop on the power inverter just fine in my laramie
Old Jun 1, 2009 | 09:43 PM
Hdcowboy's Avatar
Hdcowboy
Originally Posted by sarguy01
I think it is an option on the SLT's, don't quote me. The consoled trucks have them.
I have it on my SLT but then again its got the console option. Earlier in this thread I posted t was good for 10 amps but I just went outside an looked at it said 150 watts, heck that only makes it good for a little over 1 amp.
Old Jun 1, 2009 | 09:47 PM
Hdcowboy's Avatar
Hdcowboy
Originally Posted by Justin89
i doubt your outlet is good for ten amps if its the stock one i think its good for 150 watts
which is 1.36A
yep your right, heck my drill motor probably pulls more than that!
Old Jun 1, 2009 | 10:22 PM
plumcrazy73's Avatar
plumcrazy73
it comes with the premium seats i beleive
Old Jun 2, 2009 | 01:20 AM
Justin89's Avatar
Justin89
haha yah your drill would for sure pull more then that that plug in the dash is really only good for cell phone chargers and laptops lots of people debate that they are not good to use to charger cordless tools because of the square wave as mentioned but lots also say they have never had a problem .. im not educated enough to really argue either way but at 150 watts its more of a decoration ..for myself any ways
Old Jun 2, 2009 | 01:04 PM
usp45compact's Avatar
usp45compact
Yeah unfortunately mine didn't come with the inverter in the dash. It's an SLT Bighorn. I have a couple small ones i've used in the past, but they overload when I plug things like a laptop in them. I checked the stickers on some of the appliances in my house and suprisingly, of all the things I would want to temporarily run off an inverter, the space heater took the most juice. Says it requires 1500 watts to run. The deep freezer requires a lot to start, but took I think only took 400 watts running.
Does anyone know a way to tell how much power the alternator produces? Would it say on it somewhere? Is there a resource that might tell you this? I've tried googleing it and had no luck. I'm thinkinking I mainly need to know the amps, right?
Wouldn't the alternator (amps) x volts (12) = watts and thus give me an idea of the maximum watt inverter I can use? I'm not really electrically savvy, this is just what I've come up with so far.
Old Jun 2, 2009 | 02:45 PM
oldjeep's Avatar
oldjeep
There's really nothing to argue about - some AC-DC convertors will work with a square wave and others need the sine wave. Only way to know for sure is to try it.
Personally I wouldn't bother for cell phones and laptops, since 12VDC cords or DC-DC step up transformers are usually available for both.
Old Jun 2, 2009 | 05:33 PM
ousig2408's Avatar
ousig2408
guys you are talking about the trucks electrical system that runs at 12 volts NOT 120 volts like your house...most stock plugs put out about 100 watts or 10 amps max.
Old Jun 2, 2009 | 05:36 PM
oldjeep's Avatar
oldjeep
No, they are talking about the built in DC-AC invertor that some trucks have.
Old Jun 2, 2009 | 05:37 PM
ousig2408's Avatar
ousig2408
Amps x volts = watts
10 x 12 = 120
EDIT - sorry guys if I misread the discussion...it seems I may have according to OLDJEEP
