airbags
Old Jun 20, 2009 | 01:16 PM
hemiman1's Avatar
hemiman1
Default airbags
I have a 2009 1500 laramie,I installed airlift 1000 air bags in the coil springs, this does not give enough support when my 5th wheel is on the truck,is there anyone else who has had this problem, and if so what did you do to rectify it.
Old Jun 20, 2009 | 02:53 PM
qicvick's Avatar
qicvick
sounds like your way overloaded, I would say short of a 3/4 ton, going with a different spring
Old Jun 20, 2009 | 03:18 PM
hemiman1's Avatar
hemiman1
Default airbags
I towed with a 2006 hemi with helper springs and 8500lb trailer( same trailer) and no issues
Old Jun 20, 2009 | 03:20 PM
hemiman1's Avatar
hemiman1
I think these coil springs are great for the ride but terrible for supporting the weight
Old Jun 20, 2009 | 03:24 PM
oldjeep's Avatar
oldjeep
Do they even recommend towing a 5th wheel with an 09 1500?
Old Jun 20, 2009 | 11:11 PM
Inbred's Avatar
Inbred
They don't say you can't, but there's very few 5th wheel trailers whose hitch weights would allow it.
Old Jun 20, 2009 | 11:26 PM
HammerZ71's Avatar
HammerZ71
Wow, in my state, they see you with a 5th wheel on a 1/2 ton truck the troopers will pull you off the road and make you unhook and get a truck rated for it to come get it, and hit you with some hefty fines.
Not to mention if you have an accident, your insurance will leave you high and dry for being overweight.
The 1000s are way too low capacity for you, you should have gotten the Ride Rites (2000s') which I have or even the 5000s...
Old Jun 20, 2009 | 11:31 PM
Ryan Albert's Avatar
Ryan Albert
Making multiple topics on the same issue won't get you more answers, just annoyed people. Seems like your having trouble because 1500's are not meant to tow most 5th wheels out there.
Old Jun 20, 2009 | 11:33 PM
bigred3297's Avatar
bigred3297
i've heard of this happening quite often where i'm from in Tx, it's dangerous. Did a shop recommend the 1000's? Maybe you can exchange because of their mistake...
Old Jun 21, 2009 | 07:28 AM
hemiman1's Avatar
hemiman1
Default ride rite 2000
are these an air bag that fit inside the coil,and if not,how do they mount on the 2009 dodge 1500, and is your vehicle a 2009
