Electronic Range Select On The 545RFE
Can anyone tell me if the Electronic Range Select on the 545RFE automatic transmission allows for the driver to actually hold the transmission in a selected gear similar to a manual transmission or if it only allows the driver to limit the top gear that the transmission will shift into but not limit what the lowest gear is? I have not been able to find the answer to this yet and I would like to know before I receive my 09 ram.
Thank You.
Thank You.
Thank You.
Thank You.
lol
The trucks with floor shifters show the gear in the evic too.
Trending Topics
Thank you all, I thought that was how the system worked. I just thought I would clarify because I had a sellsman tell me that you could actually shift the transmission into 2nd to make it easier to take off in the snow. I thought that he was full of it but I didn't have time to take the truck out and show him.
Only the GM products will lock in 2nd gear rather than starting in 1st. The Chrysler tranny will allow you to limit up shifting until you bump the rev limiter. Yes, the tranny ratios are tighter when you shift yourself. There are actually 6 ratios that can be selected by the computer. The 2-3 auto vs manual will show a huge rpm difference in the two 3rd gears.
