TRX4 Leveling Help/Question
Old Jul 9, 2009 | 08:41 PM
  #21
c0mf0rt's Avatar
c0mf0rt
Ok now for the dum dum question. The spacer goes on the top of the shock tower correct? Just under the engine compartment.
Old Jul 9, 2009 | 09:01 PM
  #22
Ryan Albert's Avatar
Ryan Albert
If you get a strut spacer. the coil goes on top of the coil which will require a spring compressor for the front if you went that route.
Old Jul 9, 2009 | 11:48 PM
  #23
c0mf0rt's Avatar
c0mf0rt
Alright thanks man. Aside from that and back the Ryan Albert show. Are your lights blacked out? If so, better pic and how?
Old Jul 10, 2009 | 10:41 AM
  #24
Ryan Albert
Mine are blacked out, did it the old bake in the oven way. If you goto my photobuck: user ryan2589, you will find pretty good pictures. It was a hassle no lie, but in the end worth it because its looks sick.
Old Jul 10, 2009 | 03:24 PM
  #25
c0mf0rt's Avatar
c0mf0rt
Ballsy.... I'm still to much of a chicken to pull the trigger on it. I checked out your photobucket....truck looks awesome. So how did you seal the lights back up? Any moisture?
Old Jul 10, 2009 | 04:03 PM
  #26
Ryan Albert
Thanks for the compliments!
No moisture yet can be seen, and I have had dewy mornings.. I also sprayed the hell out of them with the hose to see if water got in, and none did. I used a silicone adhesive in the stock location. Once that dried I went over the entire area where the two pieces meet with another layer of black gasket maker. If you get black it is not noticeable with the lights in. Do it neat, and take your time. Patience is a key. I baked and scraped each one for 1-2 hours straight to get them open. Just have to keep doing it until you finally get them. Looks awesome and is legal.
