tranny gear grind into reverse
Old Jul 10, 2009 | 07:54 PM
greenblur's Avatar
greenblur
Default tranny gear grind into reverse
I have a 2009 Ram, SLT CC with about 2600 miles. I started hearing gears grind when I go from Park to Reverse. It's not really loud, but I'm still guessing its not right. This only happens once the truck is turned off and then put back into Reverse from Park, it will not do it from Drive into Reverse or Park into Reverse after the first move out of Park. I let the truck warm up and fluids circulate so I don't think it is that. I'm not parked on an angle. I'm going to check the fluid level, but is anyone else experiencing this?
It's going back to the dealer to be checked out, but I thought I would check with the forum as well.
thanks
Old Jul 10, 2009 | 08:19 PM
MMMMRice's Avatar
MMMMRice
I have the exact same thing. I didnt take my truck to the dealership yet I keep procrastinating.
Old Jul 11, 2009 | 12:00 AM
M15's Avatar
M15
I think that noise is normal cause my 06 did it and so does the 09.
