What rear axle in 09 Ram 1500's?
Old Jan 31, 2014 | 02:24 PM
  #51
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by brando0826
Hey man you seem to know your stuff , I know this is an old thread but I just came across it. I've got a 2010 ram 1500 sport 4x4, mine has the 3:92 gears but I'm looking to upgrade for more low end torque. Any advice on what I need to order for the front and rear ?
You would want to go with 4:56's to make it worth your while. The stock carrier cannot handle 4:56's unless you shave down the carrier pin. Aftermarket carriers will allow the lower gear ratio with no alterations.
9.25" out back
8" up front
You need the Masterl install kits. If you have >50kmi, I would change the rear axle bearings and seals while you have everything apart.
Originally Posted by capsfloyd
My 09 has cc Rambox with 321. When t hey did the recall on the pinion nut, the replaced the whole insides . I ask the service advisor about changing to 355 and sh ed said she could not for this was a safety recall . I wo Ildefonso like to have the 355, I have 197,000 on the clock . I tow a travel trailer and tow it in 4th or 3rd gear .
mine was a early build with Rambox , Slt with extras. I believe the sport model came with the 355, then 4 wd has the 392. I contacted a large gear and axle Company about changing to 355 . They told if I went with non mopar gears they would whine .
thanks
Depends on the gear manufacturer. Richmod generally whines because they have a softer metal compound. Most will not whine if set up correctly.
I would not swap 3:21 for 3:55. Not much change. You should jump to 3:92 for a notable difference.
Old Jan 31, 2014 | 02:28 PM
  #52
dirtydog's Avatar
dirtydog
Moderate User
brando....
Basically everything you would need beside's fluid.
http://www.riversidegear.com/differe...-and-rear.html
I'm, not sure what gear or bearing they are providing. I would go with Timken bearings if you can help it. Also, get a double lip Pinion seal from NAPA. The standard ones are notorious for leaks.
Old Feb 3, 2014 | 08:57 PM
  #53
kddsRam's Avatar
kddsRam
I did yukon 4.56 with a master rebuild kit from Randy's ring and pinion and had a local trans and rear shop install on the F150 fx4 from the stock 3.73's. Fronts are reverse cut. No issues with getting them into the stock carrier and no whine at all, BUT.... my .02.. that was way too much gear for only 33" bfg all terrains. Unless your tuned and have at least 35" tires, 4.10 is about all I would do if your truck is even a parttime daily driver.
Old Feb 27, 2014 | 06:28 AM
  #54
D0dgeRam1500's Avatar
D0dgeRam1500
9.25" out back
8" up front
So the IFS in a 4th gen Ram's is a Chrysler 8 inch? Are there LSD's available for it?
Old Mar 3, 2014 | 08:16 PM
  #55
Old Man with a hemi's Avatar
Old Man with a hemi
Originally Posted by War Horse
Ah, so the 9.25 is a Chrysler axle. Good to know. I'm a Dodge newbie, so I'm still learning the ropes of products.
My Sport has the 3.55. How easy would it be to upgrade it to the 3.92 LSD or something within that range? Can you change the gears out without swapping the whole axle? Lastly, is that something the Dodge dealer could do, or do I need to find an aftermarket shop?
9.25 is the housing size not the axle size
