RRT Description Thread
Old Aug 5, 2009 | 12:45 PM
jawsdc's Avatar
jawsdc
Default RRT / TSB Description Thread
Updated 06/17/2010
Compilation of RRT IDs from other threads in this forum.
08-007-10 - (TSB) ECO/Fuel Saver light activation
08-018-- Engine Controls - TIPM Update For ECM PROM Update Issues
08-071--flash cluster for odometer issue
08-077--sirius inop due to initial subscription set to less than 1 yr.
08-081--crew cabs w/ sunroof. sunroof drain tubes
08-093--non-memory power pedals wont adjust. restore vehicle config through TIPM
08-101--inspect tailgate cap for warping or loose, replace if needed.
08-100--replace muffler. only factory duals w/ "quiet" muffler.
09-004--pcm flash for spark knock 1800-2500 rpm and/or NVH improvements in MDS
09-010--washer sensor weepage, replace washer harness w/ overlay
09-011--inspect ram box lids for warping, replace if needed (come pre-painted)
09-018--flash RER radio for update
09-020--zip tie rear axle vent tube to frame for possible hanging down
09-023--flash park assist module.
09-024--lube passenger seat rail or whatever (for creaking)
09-029--inspect for hood squeak
09-035--tailgate cover (taping)
09-041--2009 DS FLASH ABS/ESP MODULE
09-063--2009 DS - RAMBOX LOCK REPLACEMENT
09-084--Replace hood ajar switch
09-095--Inspect Window Molding
09-096--lens.lamp, high mounted stop lamp, replaced lense
10-009--Replace Exhaust Manifold Bolts
10-029--Replace Axle Disconnect Seal
14-001-- Fuel System - Difficult Fuel Fill/Nozzle Shuts Off
18-019
-- Engine Controls - MIL ON/Multiple DTC's Set
22-001
--Wheel shake/Tire flat spot
22-002
-- Wheels/Tires - Chrome Clad Wheel Balancing Information
26-001
-- Maintenance - Fluid Flushing Information
RECALLS:
J-10 -- Wiper Motor Replacement
Unidentified: none
Please respond with any additional RRT IDs or qustions about RRTs not listed above. I will update as needed.
Old Aug 6, 2009 | 02:47 AM
BubbaRadioNetwork's Avatar
BubbaRadioNetwork
09-035 is for the removal of tail gate cap to install double sided tape. Does not apply if you have a bedliner.
Old Aug 6, 2009 | 03:43 AM
BIGGS000's Avatar
BIGGS000
09-041: 2009 DS FLASH ABS/ESP MODULE
08191090 Module, anti-lock brake control - replace reprogram anti-lock brake control module (B)
that's what my invoice from Monday says.
Old Aug 6, 2009 | 09:43 AM
jawsdc's Avatar
jawsdc
hey bubba,
if 09-035 is the tailgate cap, what is 08-101?
thx Biggs
Old Aug 6, 2009 | 12:24 PM
savage_46's Avatar
savage_46
Originally Posted by jawsdc
hey bubba,
thx Biggs
101 came out late last year, dealt w/ the black tailgate cap for warping or lifting up (IIRC). 035 basicly supercedes 101. 035 is to add tape to inside of cap lip to do a better job of preventing lift up. even though 101 & 035 deal w/ the same thing, and 101 should now be canceled; 101 will still apply to affected vehicles if not yet completed (i had one a few weeks ago). but warranty probably wont pay it.
Old Aug 6, 2009 | 02:32 PM
BIGGS000's Avatar
BIGGS000
I don't know if this is related but nothing else was done to my truck except a water test for a weather seal on Monday. My MDS doesn't come on as often. I drive the same way in the same place. The update did change the clock as well as the engine hours (the one that counts hours minutes and seconds not the other that just shows the hours). That's probably due to having to reset the system. I am a little upset that it seems to have messed with the MDS. Although, for now I'm still on track for my 13 city MPG. just throwing extra info out there. Hope I'm not cluttering anything.
Old Aug 8, 2009 | 12:04 AM
Brummo's Avatar
Brummo
Anyone know the issue with ABS? Why the 09-041--2009 DS FLASH ABS/ESP MODULE.
Had it done today, not sure what the issue was.
Old Aug 10, 2009 | 08:18 AM
BULLRAIDER's Avatar
BULLRAIDER
I moved it to faq's
Old Aug 10, 2009 | 08:26 AM
BULLRAIDER's Avatar
BULLRAIDER
Moved
Old Aug 10, 2009 | 03:44 PM
savage_46's Avatar
savage_46
IIRC, its for ABS coming on in certain turns w/ normal driving. when i get time, ill look it up, see exactly what it fixes.
