Steering seems wierd
Old Aug 20, 2009 | 12:15 PM
tmot35's Avatar
tmot35
Default Steering seems wierd
Ok I installed a lift and level kit, and had an allignment. I find the truck drifts all over the road unless I hold the steering wheel super tight.
Old Aug 20, 2009 | 04:39 PM
72combo's Avatar
72combo
Oh thank you for saving me money , I was gonna do it although I felt it a waste of time and was told not good idea for the 09 cuz of the rear suspension, you are the 9th out of 12 that I know that arent happy.
Old Aug 20, 2009 | 04:40 PM
sking's Avatar
sking
Did you use the Daystar kit?
Old Aug 20, 2009 | 08:22 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Your caster is effected when you alter the ride height of a vehicle. I am not even sure if its adjustable on your truck with or without some sort of kit. If the caster has been effected, it usually causes the steering to be very touchy, and sensitive, causes wonder, and makes it very sensitive to road changes, which could explain your drifting all over the place. This is mainly true with equal caster on both sides, but it being too negative.
The fact is leveling kits are a cheap option, and they usually don't take into account these sort of some what critical things.
Talk to an alignment shop, hopefully they can adjust the caster and get it right. What you may wind up with, is them putting the caster way out of the spec that a stock truck would normally have, but it fixes the problem. They will need to play around. Usually, the rule of thumb is add some positive caster and it should improve the symptoms your describing.
Old Aug 20, 2009 | 08:29 PM
turk1270's Avatar
turk1270
caster and camber are adjustable on our trucks,sounds like the shop did a toe and go alignment.did the shop give you a printout of before and after
Old Aug 20, 2009 | 08:37 PM
MonkeyWrench4000
Yeah hopefully your not using a Mavis Discount Tire, with the "HawkEye" alignment machines, they are junk. Ive never had that machine do a proper alignment on any vehicle Ive ever owned. Go to a firestone, and always get the print out sheet.
Get that caster fixed.
Good Luck!
Old Aug 21, 2009 | 11:29 AM
tmot35's Avatar
tmot35
Thanks, I have a printout somewhere that I will try to find, in the mean time I think I will bring it back and explain the symptoms and see what they can do.
