New member with a couple questions
Old Aug 22, 2009 | 02:22 AM
dizzyttc's Avatar
dizzyttc
Default New member with a couple questions
I am in Toronto and bought an 09 Ram quad cab SLT Hemi about two weeks ago. I love this truck so far. The outside temperature reading on the evic is way off. Is this a common problem not being accurate? Is there a fix? This is also a 4x4 truck. Any help would be appreciated. Thanks Also is therer a list of dealer technical service bullitins showing problems and fixes for customer complaints.
Old Aug 22, 2009 | 03:48 AM
Jgroes's Avatar
Jgroes
It isn't a celsius and farenheit issue, is it? If it is, check out page 245 of the manual, which goes over how to set the units.
Sorry, I'm not aware of a website thatg lists TSB's, but I'm sure one of the seasoned dodge owners will chime in on this.
JG
Old Aug 22, 2009 | 06:37 AM
lancelanz's Avatar
lancelanz
yes the temp reading is a RRT. they will replace the wiring harness going to the sensor(which is located behind the grille on the bottom right hand side) due to the windshield washer fluid level sensor leaking and dripping into the connector. i went in to have mine done a few months ago and the harness was on backorder but once they swapped it out it was all good.
havent seen a site with all the tsb's and rrt's listed but i know there is a tread here that members are listing what they have had done when they go in for sevice.
https://dodgeforum.com/forum/4th-gen...t-results.html
https://dodgeforum.com/forum/4th-gen...on-thread.html
hope these help you out.
Old Aug 22, 2009 | 11:15 AM
dizzyttc's Avatar
dizzyttc
Thanks for the help guys. What does RRT stand for?
Old Aug 22, 2009 | 06:26 PM
hounddogg's Avatar
hounddogg
I think Rapid Response Transmittal.
Old Aug 22, 2009 | 06:52 PM
lancelanz's Avatar
lancelanz
you are correct sir!
Old Aug 22, 2009 | 08:08 PM
T_Kizzle's Avatar
T_Kizzle
Everytime I get in my truck, it takes a few minutes for the actual temperature to appear. It stays at the temperature it was at when I turned my truck off before work.
I'll get that fixed when I go in for my next oil change shortly.
