Old Aug 14, 2015, 02:58 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
lowered my crew cab today
Old Aug 23, 2009 | 09:27 PM
lancelanz's Avatar
lancelanz
it did make the ride a little rougher but not bad at all.
as far as i know it is only for 2wd
here are some more pics that i took today
Old Aug 23, 2009 | 10:09 PM
War Horse's Avatar
War Horse
Friggin sweet looking. After seeing your truck, I've officially put the Mcgaughy's kit on my wish list. Of course I've also got to find a shop that will put it on. No way in heck I'm going to try that in my driveway.
Old Aug 23, 2009 | 10:28 PM
Doc Fluty's Avatar
Doc Fluty
wait till it setles and ends up like this....
Old Aug 24, 2009 | 01:49 PM
bballmike2's Avatar
bballmike2
They show (2) kits on Stylin Trucks...one for 377.00 and one for 562.00 but both appear to be the same which one did you get??
Did you have to change out your shocks as well??
Old Aug 24, 2009 | 03:12 PM
ran jr's Avatar
ran jr
I like the gaps on that one but I think that would be more than a 2/4 though. He's already at 2" on the front so I don't expect it to drop much more.
For those that have installed the kit, do you think there is room in the front to go lower? I'm just wanting to find out if one could use the spindles and springs to get 3-4" in the front.
Old Aug 25, 2009 | 09:13 AM
rjc799's Avatar
rjc799
Originally Posted by pdavis53
That looks great. I couldn't help but see you live in VA. Where did you find that sun. It has rained here in Yorktown all day. If you do not mind me asking how much did you spend for everything? Also did you check with the dealership about the warranty?
Get the kit, bring the rig down, we'll drop it in a day.
Old Aug 25, 2009 | 09:15 AM
rjc799's Avatar
rjc799
There is enough to drop the front with the spindles. I have been considering doing this, but the spindles are being quoted at $420 when I only paid $359 for the entire kit I have now.
Old Aug 25, 2009 | 09:28 AM
rjc799's Avatar
rjc799
Originally Posted by Netou
Thats looks awsome!
Any full side shots???
Question: I just received the same lowering kit you installed for $395 from Stylin but was wondering what way did you remove the coils in the rear???
*instructions they come with are worthless*
Did you put the frame on jack stands, then lift up one side with a jack to compress the spring (then install spring compressors) and finaly lowered the jack and remove them???
Im trying to find the easiest/fastest way to do this.
Hmmm...
Very true. We didn't use the instructions. Pretty simple after doing it on mine a while ago. Biggest help .....AN EXTRA PAIR OF HANDS. Even with throwing my back out the day before (pain killers are the shiz), we put this on with very little issues.
looks really great!
cant wait to get mine done
too bad you guys are on the wrong coast lol
ROAD TRIP! (pssst......bring your rims )
Originally Posted by lancelanz
i agree the instructions are crap. for the rear we didnt use spring compressors. we did both sides of the rear at the same time. first we jacked up the rear end under the differential and then put jack stands under the frame. then we disconnected the sway bar end links and the track bar and lowered the axle until the springs were able to be taken out. we put the new ones in and then jacked the axle back up to hook everything back up. one tip is to mount the new track bar bracket before you jack the axle back up and then as you jack it up watch the hole and as it goes up the track bar hole will line up perfectly to put the bolt in. after we put in the bolt we jacked it up until we could put the end links on. the hardest part of the rear to me was cutting the bump stop cups off.
i am gonna post some more side shots in my next post.
Not mentioned above:
- We also unbolted the shocks before lowering the rear end.
- Put the entire weight of the vehicle on the suspension before tightening up the bolts.
- After cuting off the bump stop, grind the frame smooth and paint with an epoxy (suspension) paint.
- You will need to elongate the bottom hole for the track bar locater and drill a hole for this same bracket. Other than that this it is a "plug and play" kit.
Old Aug 25, 2009 | 09:57 AM
bballmike2's Avatar
bballmike2
Which kit# did you get please? They list (3) kit #s for the 2009
Old Jun 22, 2010 | 08:43 PM
Shoes09's Avatar
Shoes09
Default Tools Needed
Ordered my 2-4 eco drop kit and would like to know what tools I should have to complete it. Ive got the standard jacks, rachets and wrenches, but want to round up everything else I dont have from my buddies. Any advice would be appreciated.
