Old Aug 6, 2015, 01:04 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
Help with Removing Interior Lights
Old Mar 26, 2010 | 04:33 PM
DIVERMAN's Avatar
DIVERMAN
subscribed.
Old Mar 26, 2010 | 04:58 PM
010 Sport's Avatar
010 Sport
also....how do you remove the overhead "console" and the dome cover? I'm sure i could figure it out but i'd hate to break anything and since ya'll have done it.....
Old Mar 27, 2010 | 05:24 PM
Usmc Mopar's Avatar
Usmc Mopar
Laboy- are you talking about the dome lights that come on when you open the doors or you can click on while you are driving?
Doc is right on the money with what he said, the LED's look cool but they are not practical for reverse lights, simply not enough of a spread to be useful.
10 Sport- Go with the cool white, they are an almost perfect match.
Old Mar 28, 2010 | 11:49 PM
Hellreiser's Avatar
Hellreiser
So I'm curious how you got the overhead console covers off. I've slid just about everything I can think of up between the light cover and the console plastic but it won't give way.
Old Mar 29, 2010 | 02:45 PM
briansg's Avatar
briansg
USMC do you have your part numbers?
Old Mar 29, 2010 | 05:49 PM
lasstss's Avatar
lasstss
You have to pry off the perimeter frame in the back. It sticks into the headliner with prongs. I had it off a while ago to do the wood grain stuff.
Had the back one off also but that one is easy, you just remove the lens. Be careful, the parts in that overhead are fragile and can easily be broken.
If you r stuck or someone else doesn't respond I could take it off again and look.
Old Mar 29, 2010 | 10:54 PM
Hellreiser's Avatar
Hellreiser
Yea, the back one was easy...but the front two I can't get off.
Old Mar 29, 2010 | 11:35 PM
crod's Avatar
crod
Originally Posted by Usmc Mopar
I got mine here: http://superbrightleds.com/led_prods.htm
the website is pretty cool because they have a link to the sylvania website : http://www.sylvania.com/ConsumerProd...lacementGuide/
this tells you about all the bulbs that our trucks have.
I changed out the Front and Back Interior overhead lights, Reverse lights, license plate lights, and the bed lights (the ones on the third brake light)
It was pretty cheap too, $47.13 including shipping
a bit of advice #1- I initially wanted to only change out the reverse lights to make them brighter so that I can see things better in the rear view camera, then I noticed how cheap they were so I decided to change them all out........BUT the LED bulbs that it tells you to replace the reverse bulbs with ARE NOT brighter than the stock ones, they just give out a hyper white type light but it doesn't light things up more. I suggest that you find some LED bulbs that put out more Lumens but have the same connector.
#2- it is going to tell you to replace the rear overhead light with a RL4410-xHP9 Rigid loop Festoon bulb-Cool White RL4410-CSHP9--Do not use this one!! this one has small loops on each end and it will not make contact with the receiver on the truck.
don't use this type: http://superbrightleds.com/specs/RL4410-xHP9.htm
USE THIS TYPE: http://superbrightleds.com/specs/festoon_4410-x9.htm
-see the difference on the ends?
**overall the LED's really look a lot better especially since they match the LED's that come stock on the Laramies under the rear view mirrors**
Hope this helps
if you get a chance could you give us a link for each bulb you bought and what it replaces... thanks
Old Mar 31, 2010 | 09:13 PM
Usmc Mopar's Avatar
Usmc Mopar
Sorry I took so long, don't have much free time. I put together this list that gives you the OEM part number and the LED replacement from www.superbrightleds.com. All of the bulbs I bought were cool white because they matched the trucks other lights, I went with the highest number of LED's and the highest lumens. You can pick which ever color you want, I would recommend you re-check and cross reference the bulbs again to ensure that it is the bulb you want. The list I put together is simply what I used and what I bought.
I whatsorUsed this cross reference guide:
http://www.superbrightleds.com/cgi-b...bulb_cross.htm
License plate
oem replacement = 168
LED link=
http://www.superbrightleds.com/cgi-b...%2FWLED-x6.htm
Back up light
oem replacement =921
LED link=
http://www.superbrightleds.com/cgi-b...%2F921-x12.htm
Ash tray
oem replacement =37
LED link=
http://www.superbrightleds.com/cgi-b...%2F74-xHP.html
Glove box
oem replacement =194
LED link = Could not find
Map light
oem replacement =212-2
LED link =
http://www.superbrightleds.com/cgi-b...4x10-xHP12.htm
Dome light
oem replacement =578
LED link=
http://www.superbrightleds.com/cgi-b...on_4410-x9.htm
Trunk/Cargo area
LED link=
I hope this helps.
Semper Fi
Old Mar 31, 2010 | 09:47 PM
laboy's Avatar
laboy
Thanks for helpful info!
