Problem with 09 ram!!!
Old Sep 22, 2009 | 11:41 PM
dubfunkstar's Avatar
dubfunkstar
Default Problem with 09 ram!!!
So I have rolled on 3000 miles on the truck and one day coming home from work I cant get out of 4th gear...once I get home and shut the truck off and turn it back on...no pro. A few weeks later now the service 4x4 light has come on andwont go away. I havent even used the 4 wheel drive yet...WTF
Old Sep 23, 2009 | 12:03 AM
Brummo's Avatar
Brummo
Hello? Mr. dealer? Fix my F'n truck....!!!!
Sorry 'bout that. Hey, was it stuck in fourth, or did you tap the shifter by accident so that it said it was in fourth on the EVIC (manual mode)?
Not sure on you 4x4 service.
Old Sep 23, 2009 | 12:53 AM
dubfunkstar
yeahs its gfoing to the dealer this sat. No I didnt bump the shift button or anything....
Old Sep 23, 2009 | 02:59 AM
bigred3297's Avatar
bigred3297
try disconnecting the battery for 10 minutes and then reconnecting it
Old Sep 23, 2009 | 07:31 AM
oldjeep's Avatar
oldjeep
Highest non OD gear is usually limp mode on Chrysler vehicles. Usually means that something went wrong with the TCU or wiring for the tranny.
Old Sep 23, 2009 | 08:27 AM
hounddogg's Avatar
hounddogg
Wasn't there a post about trans not shifting and such? It got a new PCM.
Old Sep 23, 2009 | 10:14 PM
72combo's Avatar
72combo
I notice a lot of people recommend the disconnecting of the battery, but if you have a REN or REZ radio you can do damage unless you remove the radio fuse and wait to put it back in until after you reconnect battery you can do damage it is an actual TSB issued by Chrysler...
Old Sep 25, 2009 | 08:38 AM
Scott2009Ram's Avatar
Scott2009Ram
Are you serious?
Old Sep 25, 2009 | 11:03 AM
bwimmer's Avatar
bwimmer
Default Stuck in 4th gear
Mine done the same thing 4 or 5 times before the dealer could figure it out . They made me drive it to the dealership in 4th gear and show them before they could find the problem. They done a flash and so far it has stopped doing it, but a couple of times a week it will take what seems like 5 to 10 seconds before the tramsmission goes into gear after I shift into Drive. Dealer says this is normal.... I say Bull>>>>.
Been into dealer 4 times now with this problem as well as that Terribly Annoying Vibrating Gas Pedal.....
Anybody have a fix for these problems yet ?
Old Sep 27, 2009 | 10:35 AM
gonegone's Avatar
gonegone
Mine is in the shop now stuck in 4th gear, 2 times its been in for this problem, no fix yet, they have 1 more time then its the lemon law in Ky. I,m going back to Toyota
