headlight adjustment
Old Sep 24, 2009 | 12:48 PM
reader's Avatar
reader
Default headlight adjustment
Any ideas on how to adjust the headlights on an 09 crew cab
Old Sep 24, 2009 | 01:16 PM
Mike Maples's Avatar
Mike Maples
Open the hood, look at the upper front fender sections. There will be two holes (I think it's two) but anyway there is one on each side, facing up, with little arrows beside them. Look down inside to see the adjustment screw head. I think it has a hex head with a phillips slot as well so you can adjust it with two different tools. Just aim the truck at a flat surface, turn the lights on and adjust as needed.
Old Sep 25, 2009 | 12:27 PM
nick bourgeois's Avatar
nick bourgeois
have you adjusted your headlights. the holes look very small. Was wondering what tool you use. skinny screw driver? thanks
Old Sep 25, 2009 | 02:11 PM
Thatmarkguy's Avatar
Thatmarkguy
Obviously a tool that fits.
Old Sep 25, 2009 | 10:06 PM
navyr6's Avatar
navyr6
1/4" drive ratchet, long extension and 7mm deepwell socket. not sure which direction to turn the screws for raising/lowering headlight beams.
Old Sep 27, 2009 | 01:07 AM
jacknk's Avatar
jacknk
im new here and wanted to now if your window rain guards are in chanel? The reason im asking is I bought Stampede in-chanel and they would not fit,checked part#w/company they said they were correct but took them back anyway since they wouldnt fit.What brand are yours? Sorry im off the original topic.
Old Sep 27, 2009 | 01:09 AM
jacknk's Avatar
jacknk
question was to mike maples or anyone else that could help,thanks.
Old Sep 27, 2009 | 11:38 AM
Mike Maples
Mine are the Auto Vent Shades in-channel model. I like them a lot. The fit was perfect and they don't stick out much so they blend in well with tinted windows. I wanted the WeatherTech but they were not available at the time. I believe they are available now and either one should satisfy you. The AVS are adhesive stripped front and rear. The WT are snap in front and adhesive rear...or so I'm told.
