Cab Lights
Old Oct 1, 2009 | 01:00 AM
  #21
Spihemi's Avatar
Spihemi
Im actually ordering another pair for my gf's ram so this is very good to hear thanks man.
Old Nov 21, 2010 | 01:54 PM
  #22
jayman84's Avatar
jayman84
Have you gotten them installed yet. Would love to see pics.
Old Nov 21, 2010 | 10:38 PM
  #23
DIVERMAN's Avatar
DIVERMAN
Originally Posted by Spihemi
I was wondering if i could install cab lights on my 1500? Would it be hard to do?
i don't know about the newer trucks, but i installed them on my 1999. and they had the holes marked on the under side of the roof (after lowering the headliner) all you had to do was drill them out.
Old Nov 23, 2010 | 04:03 AM
  #24
big4x4dodge09's Avatar
big4x4dodge09
i got the smoked recon cab lights for my 09 1500....it def completes it when im rollin down the road.....makes it look bigger than just a 6 in lift.... i love em...no leaks. i paid $150 installed
Old Nov 23, 2010 | 04:16 AM
  #25
big4x4dodge09
Old Dec 1, 2010 | 09:34 PM
  #26
Gary C.'s Avatar
Gary C.
Sorry to chime in so late on this, but I just found the forum. I bought the Recon smoked lights for my black '07 Ram and they looked awesome... but they leaked continually. Never had a single leak into the cab, but water kept getting INSIDE the lights and eventually corroding the contacts to where a light would start to flicker, dim, then go out. I looked like a rolling disco show going down the road.
I called Recon a number of times, and 3 different times they sent me 3 replacement lights. Aside from the fact that I had to take apart the inside of the truck to swap out the light, they never corrected the problem. I took apart one of the lights and found that the top lens sits in the base and it just isn't watertight, and the water was getting in from the top... you could actually see the moisture progressing into the light.
Since I had 15 holes drilled in my roof I eventually yanked them all off, threw them in the trash where they belonged and installed OEM lights. The amber lights didn't look nearly as good on a black truck, but no problems afterwards!
Personally, I'll never buy another Recon product.
Old Dec 2, 2010 | 12:14 AM
  #27
reeseonfire's Avatar
reeseonfire
Those look sick, would love to put the smoke ones on the top of my black truck. I wonder if they make LEDs that fit inside them, I think they'd look cooler with blue/white light coming out of them then amber.
Old Dec 5, 2010 | 11:54 AM
  #28
POWER SEDAN's Avatar
POWER SEDAN
You could always just spray-tint (Nite Shade) your OEM cab lights.
Old Dec 5, 2010 | 01:06 PM
  #29
Gary C.'s Avatar
Gary C.
Great idea! I probably should have posted when I had the problems but I had such bad luck not only with that truck but with just about every aftermarket product I tried I was thoroughly disgusted... lights, tailgate lock, brakes, leveling kit... none of it worked out on that rig. I think it was cursed!
Old Dec 5, 2010 | 01:34 PM
  #30
TRXHemi's Avatar
TRXHemi
Those recon smoked ones look pretty damn good.
On the 4th gens, is the connector in the passenger side A-arm as well??
