Lift link... watcha think?
Old Oct 13, 2009 | 10:34 AM
depunz's Avatar
depunz
Default Bilstein details
The Bilstein Kit offers a replacement strut with a move spring seat thus the adjustable lift. Here's a link to a pic. You can see the grooves where the spring seat goes. There are three different grooves. Click on the box. It will take you to the photo.
Old Oct 13, 2009 | 10:50 AM
Harmsie's Avatar
Harmsie
Thanks for the explanation. So the coil spring just expands then with whatever groove you're using? With the coil spacer lifts, does the stock strut bolt to the coil spacer?
Old Oct 14, 2009 | 07:55 AM
depunz's Avatar
depunz
Yes. The spacer goes between the strut and the factory mount on top. Here's a link to spacer lift instalation instructions.
http://www.ntwonline.com/images/Inst...ons/HEC359.pdf
Old Oct 14, 2009 | 11:22 PM
sking's Avatar
sking
There is NO spacer with the billstien kit. Thats the beauty of it.
Old Oct 22, 2009 | 01:32 PM
BOWERSFJ's Avatar
BOWERSFJ
Originally Posted by sking
Topgun customs has a new 2.8 billstien lift kit out now. If you want a small lift look into that kit. I have it on the way.
Just looking for an update on this . . . How did the install go, what settings did you use, and most important of all . . . Any "after" pics ?
Old Oct 22, 2009 | 02:46 PM
sking's Avatar
sking
still waiting
Old Oct 22, 2009 | 04:02 PM
BOWERSFJ's Avatar
BOWERSFJ
still waiting
Thanks . . . Please keep us posted
Old Oct 22, 2009 | 04:46 PM
jball's Avatar
jball
Just a FYI. I clicked on the link for the spacer kit to the instruction sheet. When you are taking apart the upper ball joints / tie rod ends on your truck do NOT hit the knuckle with a hammer. Use the correct puller tool. You can stress or even crack the aluminum knuckle. I know of two instances of broken aluminum knuckles... dont know what caused the failures (improper assembly / disassembly, or just wear and tear), there is a note in the factory service manual about this.
Old Nov 3, 2009 | 08:32 AM
Harmsie's Avatar
Harmsie
Hey sking, did you ever get these installed? Just wondering what you thought of them?
Thanks
Old Nov 20, 2009 | 06:08 PM
RamAirman's Avatar
RamAirman
I'm SO anxious to see this!
