Somethings wrong
Old Oct 15, 2009 | 02:28 PM
09 Ram TRX 4 Lover's Avatar
09 Ram TRX 4 Lover
I have the same issue with mine. It is a TRX 4 as well. mine dose it at 3,000-4,000 rpm's sounds like crap like its starving. I miss my 06 powertrain set-up.
Old Oct 15, 2009 | 03:22 PM
SIDELOCK's Avatar
SIDELOCK
Me toooo!
Rolling along at 70 mph and need to pass.
Pedal to the floor, before moving into the passing lane.
NOTHING HAPPENS! except the truck SLOWS DOWN, wait 3 seconds, THEN IT TAKES OFF!
Don't know why but it has happened from the very beginning. Same thing happened with my '03. Never could get it fixed. Dealers had no clue.
Any ideas?
Old Oct 15, 2009 | 03:32 PM
jason2922's Avatar
jason2922
Originally Posted by shep8235
Thanks for the help guys. I never notice if the there is a light on or anything. I guess that would make sense. When your tires are spinning and with that much power it would be easy to lose control. I will see if it does it tonight when I go to work and punch it on dry pavement. Then I will try it on wet pavement or even on a dirt road. Thanks again guys..
Also, try hitting the esp button and turning it off. Gas it on a dry road and see if you still have the hesitation. If so, not a TC problem.
Old Oct 15, 2009 | 07:55 PM
72combo's Avatar
72combo
They made this truck with so much available power but it is all kind like it is protecting itself from damage as well as us doing damage to something. Think is that *** end was left with nothing to control it.....it would be worse than Viper, you would be doing circles every stop light. They gave us all that power and won't let us have fun with it but when you need it...trailer, whatever you are set.
