Crappy headliner.
Old Oct 15, 2009 | 11:30 PM
Grimacus's Avatar
Grimacus
Default Crappy headliner.
Anyone notice how crappy the headliner is situated, you can move it up like an inch. I also noticed on mine the homelink button/console is loose or something, when I go to hit the map lights, I can get the front console part closest to the windshield to start dropping down and then I would have to push it back in.
Old Oct 15, 2009 | 11:56 PM
Shumdit's Avatar
Shumdit
Your headliner is not installed all the way. There are some Velcro like pads that are used to attach the headliner in the middle areas (they are almost more hard plastic than hook and loop fibers) and the factory can be a little slack about installing them. All you have to do is locate them (easy on sunroof equipped models since you can see them in front and back of the opening) and push the headliner firmly up into them. Then you will be amazed how much better the headliner looks and the lights/overhead switches feel when pushed. Go try this 30 second fix and let me know what you think.
Old Oct 15, 2009 | 11:58 PM
Secret Agent Man's Avatar
Secret Agent Man
It sounds like yours isn't properly secured. They are just plastic clips or velcro (can't remember). So the UAW line worker didn't secure yours... If you give it a good push upward and it should snap in or adhere.
Old Oct 16, 2009 | 01:52 AM
72combo's Avatar
72combo
Or you could take it to the dealer and have them do it with dirty hands or some other reason to damage something else.
Old Oct 16, 2009 | 10:25 PM
Grimacus's Avatar
Grimacus
Well I played with it today, right above my head it seems secure but toward the middle of the cab where the hump comes down seems to move up like 1/2 inch. I will see monday when I take it to the dealership.
Old Oct 16, 2009 | 11:51 PM
Medic1's Avatar
Medic1
I agree with above replies, my headliner is in there pretty securely.....
Old Oct 17, 2009 | 09:34 AM
CarterT1975's Avatar
CarterT1975
+1 mine too...
Old Oct 20, 2009 | 07:24 PM
budlyte's Avatar
budlyte
Thanks for the tip. This worked for me.
Old Oct 21, 2009 | 11:31 PM
vincey2kr1's Avatar
vincey2kr1
got the same problem on mine too, gonna give this a try too
Old Oct 22, 2009 | 10:09 PM
Grimacus's Avatar
Grimacus
Took mine to the dealer, they said its normal, they looked at others on the lot and said they were the same. They did have to order a new console where the map lights are...
