Help How do you remove safety decals ?
Old Oct 17, 2009 | 04:49 AM
Longbow's Avatar
Longbow
Default Help How do you remove safety decals ?
Yep I want to remove those safety stickers on the sun-visors . Now I removed one but left glue residue , so what solvent would one use ?
Old Oct 17, 2009 | 08:58 AM
Renegd98's Avatar
Renegd98
I would venture to say they are not designed to be removed.
Old Oct 17, 2009 | 11:30 AM
usp45compact's Avatar
usp45compact
Be careful to test what ever solvent you go with on a tiny hidden spot first. A lot of solvents/adhesive removers will completely screw up a plastic finish. My poor office phone found that out the hard way...
Old Oct 17, 2009 | 01:42 PM
Longbow's Avatar
Longbow
Default Try paint solvent & soap and water
The answer would be paint thinnner on a soft cloth , then wash down with mild soap and water and rinse with clear water
NB I only remvoed the bilingual stickers that overlay on the English stickers .
I'm done
Old Oct 17, 2009 | 08:13 PM
72combo's Avatar
72combo
If it is solid plastic try WD40 it removes glue good, make sure it is not an absorbent material.
Old Oct 19, 2009 | 10:22 AM
looperk2's Avatar
looperk2
I use a product called "De-Solv-It" to remove any kind of glue residue I come across. It works really well and hasn't stained/ruined the finish on anything I've put it on. Plu,s it's made from oranges so it smells nice.
Old Oct 19, 2009 | 09:33 PM
72combo's Avatar
72combo
Lots of stuff that is safe like Goo-Gone.
Old Oct 21, 2009 | 10:04 AM
nick bourgeois's Avatar
nick bourgeois
longbow, how did you remove the sticker???? i have been picking at it for a while and got tired of it. I hate it there.
Old Oct 21, 2009 | 06:01 PM
72combo's Avatar
72combo
switch visors from side to side them it wont be in your vision all the time?
Old Oct 22, 2009 | 02:10 PM
Longbow's Avatar
Longbow
Default heat gun or hair dryer
Nick, I took a hair dryer ( you should be careful here) and warmed up the label on the visor then gently started to lift it off .
