4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
on the air box there is a breather hose fitting that is secured with locknut and washer ...after 20k miles of normal engine vibration... it came loose was sucked into intake and destroyed my hemi....
yes ... i bought the hood and air box for my 07 ram 3500 5.7 hemi... called ram air to ensure it was a plastic nut that came loose.. it is.. appears that it has gone into valve port and holding a valve open.. truck runs rough and backfires ... dodge is tearing it apart as we speak... ram air says this is first they have had one come loose.. i suggest anyone that has this setup .. to take nut off and epoxy fitting in place... i dont know that lock-tite will work on plastic... but ram air says to try it ...lol .. i'm not risking it ...epoxy seems more reliable way to go
