Low Tire Pressure warning symbol, and warning message in the computer.
Subscribe
Oct 20, 2009 | 07:57 PM
I just got done checking the pressure in my tires, they are all around 35-37 PSI. But the msg wont go away. Is there some sort of reset that i should be performing or am i seeing some sort of issue coming to light? It did it once last week, i filled the tires up and it went away. This morning, i got in to see that it was back, and wouldn't go away with a few psi added to them.
Reply 0
Oct 20, 2009 | 08:26 PM
You might have a sensor going bad. Try turning the key on (do not start) and then depress the accelerator pedal three times. Not real fast like you're trying to juke a old carb'd vehicle to get it started, but all the way to the floor, then back up, 1/2 sec, down again, etc.
Reply 0
Oct 20, 2009 | 11:10 PM
Mine lit up last week for the first time. Went and checked and they were all at 32. Filled them all up to 35, and when I started it up - the message and light were gone.
Reply 0
Oct 20, 2009 | 11:47 PM
I think there is a Tire Pressure Sensor in the spare tire too. Might want to check to make sure the spare isn't low.
Reply 0
Oct 21, 2009 | 01:45 AM
The individual TPI readings for the 2010 is one feature I hope we see a software update for our 2009s. I had one go bad 2 weeks after buying the RAM and it took a visit to the dealer to get it fixed.
Reply 0
Oct 21, 2009 | 09:57 AM
my light comes on every other week. pain in the aas
Reply 0
Oct 21, 2009 | 11:01 AM
Yeah, my parent's Grand Cherokee gives individual readings of each tire. I was stunned when I realized that my nearly 50k Laramie just flashed 'Low Tire Pressure' with no specifics... I was bummed.
Reply 0
Oct 21, 2009 | 11:25 AM
got the same message on mine last week, lowest pressure was 32#. it was the first cold weather (50F) for florida this year, though. filled them all to 40#, message went away.
Reply 0
Subscribe
