Homelink question
Old Oct 23, 2009 | 12:38 AM
sking's Avatar
sking
Originally Posted by renegd98
you most likely have to follow the procedure i did.,.. First program the homelink using the remote you use following the instructions in the book and then go and push the button on your garage door opener in your garage and return to your truck and push the button you just programmed 2 times holding it for 2 seconds during each push. You most likely have a garage opener that has frequency hopping and thus you have to do both procedures..
I think it is step 5... But you can go direct to step 5 until you have programmed which button you want to use.
yup what he said. The manual is not very clear about this....
Old Oct 23, 2009 | 12:44 AM
72combo's Avatar
72combo
Originally Posted by Renegd98
You most likely have to follow the procedure I did.,.. first program the homelink using the remote you use following the instructions in the book and then go and push the button on your garage door opener in your garage and return to your truck and push the button you just programmed 2 times holding it for 2 seconds during each push. You most likely have a garage opener that has frequency hopping and thus you have to do both procedures..
I think it is step 5... but you can go direct to step 5 until you have programmed which button you want to use.
Oh man that explains why one remote I have will program the homelink and the other won't. Okay forget my battery suggestion, crap a threw 2 good batteries away LOL
Good Luck
Old Oct 23, 2009 | 09:00 AM
Brummo's Avatar
Brummo
I followed the manual. I remembered doin it in my Dakkota, which helped me Doing one of my SAABs. I just wasn't pointing my remotes in the right area to make sure the signals were hitting the home link. I know it sounds weird because it is a radio signal, but it seemed to work. Bbut in all I followed the manual's instructions. I know I didn't help much, sorry.
Old Oct 23, 2009 | 01:18 PM
dgholmes59's Avatar
dgholmes59
Here is the problem I had. I did not follow the directions that said place the remote within 3 inches of the homelink button. I did that and it worked perfectly within seconds. I had the remote too far away.
Old Oct 23, 2009 | 05:44 PM
mcs's Avatar
mcs
Don't under estimate new batteries.I first tried with the old batteries, because the remote's power light would light up.Homelink wouldn't connect till I put fresh strong batteries in remote.
