Oil Change Reminder Issues
Old Oct 30, 2009 | 01:53 PM
oldjeep's Avatar
oldjeep
Those of you who are getting it at exactly 2500, do you have early build trucks with the "other" engine? Makes me wonder if either the early engines or early firmware are hard coded to 2500. The one time my light came on was around 3K. I get the oil changed every 2500 miles so I wouldn't normally see the light - dealer resets at each oil change.
Old Oct 30, 2009 | 02:04 PM
tombogue09's Avatar
tombogue09
mine comes on at around 4k miles, built nov. 08
Old Oct 30, 2009 | 02:21 PM
09RAM4WD's Avatar
09RAM4WD
just hit 2350 miles the other week and the light came on
Old Oct 30, 2009 | 03:11 PM
Kiernan's Avatar
Kiernan
I have a very early build...Oct '08. Maybe that's the issue.
Old Oct 30, 2009 | 03:16 PM
Twist's Avatar
Twist
Mines a November 08 build and the light came on at 6,000 and again at 14,500.
Old Oct 30, 2009 | 04:03 PM
topgun's Avatar
topgun
Mine's a late March truck and it came on at just over 2,500 miles so it has nothing to do with the build date.
Why worry about this? If it comes on and it is not time to change your oil, just reset it.
Old Oct 30, 2009 | 05:11 PM
matt3's Avatar
matt3
Anyone know off hand how to reset the oil change indicator. My evic says I have a message and it says to change oil soon, see dealer. The oil was just changed and the dealer didn't reset it.
Old Oct 30, 2009 | 05:45 PM
mike2810's Avatar
mike2810
Procedure is in yours owners manual. Very simple process.
Unless reset, this message will continue to display each
time you turn the ignition switch to the ON position. To
turn off the message temporarily, press and release the
Trip Odometer button on the instrument cluster. To reset
the oil change indicator system (after performing the
scheduled maintenance) refer to the following procedure.
1. Turn the ignition switch to the ON position
(Do not
start the engine).
2. Fully depress the accelerator pedal slowly three
times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE:
If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary repeat this procedure.
