4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Spring compressors, probably a easier way but it's just what I did.
That also makes no sense. When you compress the spring the truck will just sag closer to the axle. So with your process you now have the axle lifted off the ground and the frame closer to the axle yet no space between the top of the spring and the cup where you need to slip in the spacer.
Rice, I'd guess he lifted the truck by the axle, put stands under the frame, compressors on the springs, and then dropped the axle. Just a guess, but it makes perfect sense to me.
