Ren
Old Nov 21, 2009 | 08:36 PM
crod's Avatar
crod
oooohhhh. i might be waiting for this. im sure someone will make an adapter or whatever.. with my experience the rer unit is the biggest piece of crap anyone has ever made!! the ren is probably better because it doesnt do nav. but im sure the newest unit is better because of a diff. manuf.
Old Nov 22, 2009 | 05:51 PM
72combo's Avatar
72combo
Well why would you say another manufacturer would be better? First year would they be any better than Harmon Becker ? Why did they just not stay with Infinity I wonder, they were good. I personally think these things over heat. I wasn't gonna bother getting one but for 250 bucks and I picked it up from a tech in Michigan figured should work out since the uconnect i bought is the same one that goes with my cheapo original radio, so radio swap if it takes a bum. Hope it won't.
Old Jan 18, 2010 | 09:22 AM
Brummo's Avatar
Brummo
Anyone know why about every 30-40 min sound cuts off for no reason for about 10 seconds..regardless of what mode it's in. Software updates????
Old Jan 18, 2010 | 10:33 AM
Spetz's Avatar
Spetz
Originally Posted by 72combo
2010 gets a new radio RBZ I think but it is not made by Harmon Becker anymore, its now made by Mitsubishi. The antenna connection is not the same so you would probably have to buy a new antenna unless someone has a convertor.
I've got a 2010, and it still came with a REN. It only freezes when selecting next song on the HDD. But all I have to do is hit the "NEXT" button again and it works..
Old Jan 18, 2010 | 11:37 AM
LUBINATOR's Avatar
LUBINATOR
One thing to remember is that if it is the model with a hard drive, it is a computer. Ever have a computer lock up for no good apparent reason? If it continues to happen it could be related to heat, the audio units generate a pile of therms. Lay your hand on yours after you play it for a bit. Even in the winter, remember the truck is warmer and the audio unit is still generating heat.
Another question would be if it has ever happenned with the audio units controls that are on the unit.
The wheel controls just send a signal to the main unit to do their jobs. The unit itself has the interface to do that, and again the unit is the one with the heat on it.
This is just one reason that I can see this happenning. One of the others could be some interference from any aftermarket electronic controls that may have been installed, as well as the unit itself is intermitten or just prone to having this happen.
The next time it happens, do not touch a thing, drive to the closest dealer, do not turn off the truck, and ask them to come and see it happenning.
I am having trouble with the electronic info unit on my 2009 1500 with all the temp readings. Ambient air, trans, and coolant readouts. All three can vary up and down at times, and all the sensors have been replaced. I keep telling them it is the control unit(the computer).
Just some possible input from an audio/puter nut.
Good Luck
Richie
Old Jan 18, 2010 | 12:11 PM
c0mf0rt's Avatar
c0mf0rt
Good Luck
Richie
Took the words right outta my mouth.... it's softare... and as well all know, it can be glitchy. The more it does, the more it can get screwed up.
