H.I.D acting up
Old Nov 19, 2009 | 01:17 PM
cpelton's Avatar
cpelton
Originally Posted by Doc Fluty
look on the side of the ticket where it says "code and section" and there are yes and no boxes. If yes is checked, then its a fix it ticket. more on this can be found on the back of the ticket by letter (c.)
but anyway.. yeah mine is a fix it ticket.. got me in some silverstars now... they light the road pretty good.. but have a ugly warm light thats on the road... so ill be switching back soon
I thought those would be heat score! get some 6000k bulbs, i've had them in my last 3 vehicles and never had a problem with the po
Old Nov 19, 2009 | 01:37 PM
Doc Fluty's Avatar
Doc Fluty
mine was working fine for months with the bulbs i got from twgy... but when i switched the bulbs to the higher temp is when one of em went out within a week or 2
Old Nov 19, 2009 | 04:27 PM
bohrman44's Avatar
bohrman44
I dont think the ballasts are bad....i figured out something interesting....when i unlock my doors via remote the headlights and puddle lamps come on.....everytime i do that both headlights come on with no problems.....its when i start the truck they go out, and i have to play the on/off game with them....well today i unlocked my truck, let them stay on for a minute then turned my truck to the "on" position, waited for 5 seconds or so then started, and voila! they stayed on.....I'll keep trying this to make sure, but I think I may have found a way to make them work....its that split second between the on position and the actual start where they go off......we'll see though.....the lights are awesome when they do eventually come on!!! I ordered the fogs today....haha
Old Nov 19, 2009 | 07:01 PM
TZM's Avatar
TZM
im having the exact same problem, same company, same hids. i got the relay sent to me, now they only turn on when the engine is off. if the engine is running then they wont stay on, just flash. also, if i turn them on then start the engine right away they turn off. they need that 5 second delay. so this problem has essentially rendered my remote start useless at night becuase i will jsut need to turn off the truck to turn on the lights, pause.......then turn on the engine. booerns. they say its just a bad relay. i think its more than that, they are sending another relay right now.
Originally Posted by hawk570
Guys, add a relay and that will solve all your problems and avoid any future problems with your trucks electrical system. On most dodge vehicles, if not all, a relay is needed or suggested.
Old Nov 19, 2009 | 07:11 PM
Thatmarkguy's Avatar
Thatmarkguy
Sounds like you guys need cancelers.
Old Nov 19, 2009 | 07:21 PM
jake09's Avatar
jake09
i was considering getting a set of hids but after all the negative feedback on lights going out, flickering, or not even coming on...i think ill stick w/ my halogens...they may not be as bright but they turn on every time i turn the switch over haha
Old Nov 19, 2009 | 08:10 PM
bigred3297's Avatar
bigred3297
Your problem can be solved with cancellers... I guess you didnt read the HIDExtra thread because it states what you need to order and what to tell them you need when you order. A lot of people have bulbs from them with no issues, just have to follow directions
Old Nov 19, 2009 | 08:11 PM
crod's Avatar
crod
are these from hidextra on the forums here? i havent heard of everyone having these problems...
Old Nov 19, 2009 | 09:48 PM
TheBayouCity's Avatar
TheBayouCity
I installed the HIDextra lights last night. Not as easy I thought it would be. After I did the first one, the 2nd was a breeze. But it was the first one that really did it for me. I asked for the cancelers and so far so good, but it's only been 1 day.
I got the 8000k set. It seems a little too blue for me. Not too much, but I'm just use to the stock HIDs on my S2000. And for those who don't know, those stock HIDs are some of the best out there. I might try the 6000k bulb, those will probably give the cleanest pure light.
Old Nov 19, 2009 | 10:02 PM
lancelanz's Avatar
lancelanz
that is why i got the twiggy HID's. yeah they cost more but i have not had to get cancelers or relays. all plug and play with no problems even with the flooding that happened here last weekend and driving through some pretty deep water. it all goes back to the old saying "you get what you pay for"
JMHO
