4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Owners manual calls for tire rotation every oil change, is this really necessary considering that oil is changed every 5000 kms? Can I get away with rotation every other oil change?
i've always owned 4wd vehicles and I rotate my tires every other oil change. I think that doing it every time is a bit excessive. I'd also recommend getting them rebalanced at each rotation to avoid any wobbles.
These tires really arent the best. I get a coupon once a month for tire rotations for $9.99. Well worth it to make these tires last as long as possible.
Someone probably said this already but the book in Canada says 10000km's between oil changes.
I will dump these tires within 2 years, I just don't even like the look of them. I will be going with some Falkens.....luv them.
