problems after putting in leveling kit?
Old Nov 23, 2009 | 09:55 AM
crod's Avatar
crod
Default problems after putting in leveling kit?
hey guys. i have a sport 4x4 quad cab. im planning on getting a front leveling kit and throwin some bfg all terrains, 285/65/20's.
since i know they will fit without the leveling kit, i was just wondering if i will experience problems, premature wear to anything up front by putting the leveling kit on?
im assuming i need to get a wheel alignment after adding bigger tires and the leveling kit?
Old Nov 23, 2009 | 02:25 PM
Scottyluck's Avatar
Scottyluck
https://dodgeforum.com/forum/4th-gen...-problems.html
You will definately need an alignment.
Old Nov 23, 2009 | 06:37 PM
kddsRam's Avatar
kddsRam
Like others have said, alignment is a MUST as the toe will be way off when done. I had 70k on my F150 with front levelers and a rear add-a-leaf and no issues or tire wear, basically a low budget lift kit. The rear is too soft on these trucks without the leafs so I would not do the front without the back. Curious if they make the same spring block for the rears. That would be nice...
Old Nov 23, 2009 | 11:24 PM
crod's Avatar
crod
kddsram. being to soft. are you talking about if was to put a load in the back, getting some rear squat?
dont worry, its a glorified car.lol. i have a work truck to beat up, not the ram.
