Wheels
Old Dec 3, 2009 | 12:37 PM
dizzyttc's Avatar
dizzyttc
Default Wheels
I have the 09 ram qc 1500 4x4. Someone locally is selling a set of Mickey Thompson MTZ on dodge 20 inch rims off an 06 1500 4x4. Tires are 325/50-20 which would be 33 inch. He said they were on a stock ram. Was there anything different on the 06 that would allow them to fit? He says they didn't rub at all. I want to know if I can fit them on my 09 without rubbing. Anyone here try 325/50-20 on stock 20,s? Thanks
Old Dec 3, 2009 | 02:06 PM
CarGuyOhio's Avatar
CarGuyOhio
If they worked on the 06 they will work on the 09
Old Feb 1, 2010 | 09:12 PM
Moparmeister's Avatar
Moparmeister
I'm not so sure...others here have had rubbing on full turn with 305's...
Old Feb 1, 2010 | 09:19 PM
TI 3VOM's Avatar
TI 3VOM
See if you can try the front ones on first. You will love the MTZ's, GREAT tires! I can't wait till I can afford a set for my truck.
Old Feb 1, 2010 | 10:37 PM
jake09's Avatar
jake09
they will rub the control arms im almost positive...bolt the rims and tires up just to make sure
Old Feb 1, 2010 | 10:43 PM
Doc Fluty's Avatar
Doc Fluty
i have 33 inch tires and my front end is LOWERED 2" up front.. i only get a lil rubbing at full lock... i think on a stock height truck they should be fine
Old Feb 9, 2010 | 09:35 PM
bvigne01's Avatar
bvigne01
The 3rd gen had bigger wheel well openings then the 09. They reduced the wheel well size so the tires would fill them up better and it would lower drag and improve MPG
Old Feb 9, 2010 | 11:59 PM
dizzyttc's Avatar
dizzyttc
Well I never got to try the 325/50-20MT. I think they were sold but looking at the space between the tire and the upper arm I really don,t think they would have fit. I am wondering if a 33/12.5-17 would fit? The stock 20,s are 33" tires. I am trying to put the biggest and widest tire on the truck without a lift or level.My truck has the 17" alloys so I will be buying rims as well.
