HID Wiring Pics for Quad headlights
Old Dec 11, 2009 | 11:16 PM
drought_buster's Avatar
drought_buster
Default HID Wiring Pics for Quad headlights
I purchased the HIDextra.com HID lights and used Lancelanz's tuturial on how they installed their lights. One of the issues I had was wiring up the headlights, So I took a few pictures in hopes to clearify some things.
LanceLanz's Post:
https://dodgeforum.com/forum/4th-gen...installed.html
One of the things Lance says he had to file parts and cut tabs off the wiring harness to make all the wires fit together. I didn't have to in my case. Here is a picture on how I got the wiring to work in my truck.
I purchased a 25mm hole saw to cut a hole in the low beam cap. I also drilled a 3mm pilot hole to help center up the hole saw cutter.
I then cut the supplied harness from HidExtra that attaches to the stock light bulb and pushed the wires through the grommet. That way I am able to seal the headlight back up.
Once The cap was installed I pulled the grommet up into the cap. I then used some 18-22 gauge butt splices that were raychem heat shrink to waterproof the connection. The raychem are buttsplices that you heat up with a heat gun that will shrink onto the connector and the adhesive flows within the buttspice over the bare wires to protect and seal them.
NOTE: Make sure you install the cap first, then reconnect the wires. The end connector on the floor will not go thru the 25mm hole I cut. I had to cut the wire and redo the buttsplices connectors because I didn't check for clearance of the harness connector.
I hope this helps people with the install, and clears up some confusing steps in wiring the HIDextra converstion kit.
Last edited by drought_buster; Dec 11, 2009 at 11:33 PM. Reason: grammer and spelling
Old Dec 12, 2009 | 11:27 AM
crod's Avatar
crod
i thought these were strictly plug and play?
do you have the quad system with the capacitors ??
Old Dec 13, 2009 | 11:15 PM
drought_buster
Yes I have the quad system with the capacitors. This conversion kit is plug and play if you don't want to install the watertight sealing cap on the back of your headlights.
Old Jan 1, 2010 | 12:01 PM
speedgtp's Avatar
speedgtp
Thank you buster!! This helped me a ton!
Old Jan 4, 2010 | 10:46 PM
ThEOnE@ce's Avatar
ThEOnE@ce
What name brand is the capacitors kit i have a 2010 dodge truck with the quad system and i got H11 low beam and i got these capacitors on ebay and the still flicker and i would like h10 but i cant get them in canada where i live
Old Jan 5, 2010 | 08:52 PM
CanaDodge's Avatar
CanaDodge
New Member
I also bought the kit from HIDextra.com. I didn't have to cut and splice anything. yes the one connector didn't want to go through the 1" hole but all I did was removed the clip on the back of the connector and it went through no problem. Then I just reinstalled the clip.
I had the lights in for 1 week until one of the ballasts gave up the goat. HIDextra is replacing it, but in order for me to get it right away, I had to purchase another ballast and then they will reimburse me for it once they get my old one back. It's like they don't trust me. Plus I have to wait another week or better for it to arrive. I've asked them if they could overnight it. We'll see.
Old Mar 31, 2010 | 01:43 AM
NH HemiRamFan's Avatar
NH HemiRamFan
i just received my HID kit from HIDextra.com. The kit i got looks exactly like picture #4 but without the black plug to connect to the stock plug. I have separate bare metal ends, is that plug something you picked up after? And picture #1 looks like a different kit altogether. The leads off the right side (facing picture) has what looks like an inline capacitor that did not come in my kit. But it isnt present in picture#4? Anyone have any insight on this? thanks
Old Mar 31, 2010 | 06:50 PM
drought_buster
I guess im confused with your question. Maybe this will clear up any questions you have. This is the final picture with the wiring buttoned up. The wire that I cut and spliced back together came with the kit. I wanted the wires to go thru the grommet for a water tight seal. I then used some clear caulking to seal the rubber grommet to the plastic cover. The wires that I cut connect to the capacitor that was supplied with the kit. you need the capacitor to prevent your low beam headlights from flickering. If you read the posts about HIDExtra the representative for the company states that you must ask for the ballast in the comment section when you place your order (example: 2009 Dodge Ram / H11 Low Beam headlights / Need capacitor). The capacitor is free with your order. I then connected the spliced wire to the capacitor, and connected the capacitor to the ballast.
On the wires that i cut, I removed the black heat shrink tubing if that's your confusion.
Old Mar 31, 2010 | 08:59 PM
ilpoc's Avatar
ilpoc
New Member
I have a 2010 dodge ram, quad bulbs, which HID kit would i need im having trouble finding one for my low beams, ive had set of H13 for a performancee shop and they dont fit, the problem is the main connection is 3 prongs and the kit was 2 prong.. any suggestions would be great!
Old Mar 31, 2010 | 10:40 PM
drought_buster
1st issue is H13 is the incorrect bulb for low beams. H11 is the correct bulb. You do realize that the loose red and black wires in the picture above connects to the ballast, and the ballast only. You still plug the 3 prong wires into the main harness that runs to the headlights. The 3 prong wire controls your high beam and low beam. All your doing for the low beam is giving voltage to the ballast to generate the power needed to light the HID's.
