Blower Motor question
Old Dec 19, 2009 | 02:23 PM
ohioram4x4's Avatar
ohioram4x4
Question Blower Motor question
When I turn the blower on high....it sounds like it's blowing like a tornado....but the air coming out the vents, no matter whether it's the defrost, heater or panel, the volume isn't anything close to the sound or any other vehicle I have owned.
Is it just my truck....or have some of you experienced the same issue?
Old Dec 20, 2009 | 06:45 AM
Smoothbassman's Avatar
Smoothbassman
I haven't seen that one before. Maybe your blend door is stuck.
Old Dec 20, 2009 | 11:59 AM
cpelton's Avatar
cpelton
warranty, I heard someone else had bad bearings. Im beginning to think mine are going because it is quite loud on low.
Old Dec 20, 2009 | 12:35 PM
dirtydog's Avatar
dirtydog
Moderate User
2009...I doubt it's a blend door issue.
Sounds like your "issue" is exactly what my truck has always done...Meaning it's normal!
The fan screams like a ****....but seems like a medium setting breeze out of the vents.
Solution....close a few vents so the airflow is more directed. it's a big cab and the ducting is large. My guess is the fan echoes through the venting and has all to do to keep up with pushing the volume of air through the vents.
Old Dec 20, 2009 | 02:58 PM
2010sltsprt's Avatar
2010sltsprt
Yea the blower motors on these trucks is loud i did what dirty dog said it helps me
Old Dec 21, 2009 | 04:05 PM
ohioram4x4's Avatar
ohioram4x4
Red face
Got an appt at the stealer tomorrow.....I sure hope you are wrong and there's a blockage somewhere!
I'll let you guys all know what I find out!
Old Dec 23, 2009 | 10:12 AM
ohioram4x4's Avatar
ohioram4x4
Angry
Went to stealer yesterday.....here's what the work order says "diagnostics found HVAC system working properly. No codes in system. Checked calibrationn and it is OK. R&R blower motor to check for any obstructions. Checked all vent tubes. No blockage. Found all ductwork is connected properly. Compared to new truck on lot and found operation same. No repair performed. Operating normally"
So it appers that my first Dodge ever owned has THE crappiest (POS) blower motor I have ever witnessed! And I ain't happy!
