Old Aug 5, 2015, 12:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Four Wheel Drive Guides
Print Wikipost
4x4 light just keeps blinking?
Old Dec 19, 2009 | 10:46 PM
JoesBrotherRamMan's Avatar
JoesBrotherRamMan
Default 4x4 light just keeps blinking?
I am noticing when I put my 4WD in, in either 4hi or 4 low, the light just blinks, it does stop. The 4 wheel drive is engaging but keeps friggen blinking..This normal?
Old Dec 20, 2009 | 01:17 AM
TheTattooCouple's Avatar
TheTattooCouple
Have not noticed to be honest. Just picked up my 2010 Ram 1500 4x4 and only used 4x4 once so far...next time I use it I am going to have to see.
Old Dec 20, 2009 | 06:56 AM
Smoothbassman's Avatar
Smoothbassman
4x4 high should not blink for more than ten seconds unless you engaged it going faster than 45MPH. Then it will blink until you get down under that speed.
4x4 low will blink continously until you stop and put the tranny in neutral so the transfer case can change ratios.
If it never stops blinking it's either not making it into 4x4 or the sensor that detects the transfer case is in 4x4 is broken.
In either case it means a trip to the dealer. Should be cover under warranty.
Old Dec 20, 2009 | 08:28 PM
devile's Avatar
devile
I had this happen with mine... All i did was go through the set... I stopped my truck, put my transmission in neutral, and shifted to 4 low, waited about 3 minutes and the light came on solid... then went to 4 high, waited for light to go solid... then back to 2 hi and it went out... it's like it was confused...
Old Dec 20, 2009 | 08:56 PM
sneeks's Avatar
sneeks
Defiantly isn't normal, Id have it looked at.
Old Dec 20, 2009 | 10:00 PM
JoesBrotherRamMan
That is so strange. This is exactly the procedure I did as well, and it seemed to knock it off. I think the truck had just never been engaged into 4WD, so it must have just needed to be reset. I put mine into 4low, and it went in solid no blinking, then i simply put it back into 4hi, and wahlaa, it stayed solid and hasnt blinked since. Glad it got figured out bc it was snowing pretty bad.
Old Dec 21, 2009 | 01:02 AM
devile's Avatar
devile
Glad to hear you managed to get it reset, almost should be a sticky lol...
Old Dec 21, 2009 | 03:54 PM
mnh2703's Avatar
mnh2703
i tried putting my truck into 4wd and the light blinks... it sounds like it is trying to work but the back drivers side wheel keeps spinning... the 4wd isnt working... what do you think it could be?
Old Dec 22, 2009 | 08:27 AM
jball's Avatar
jball
Do you have a service 4wd message? There is a wire harness that plugs into your front differential that activates the central axle disconnect - double check to make sure it is all of the way plugged in.
Old Mar 18, 2011 | 09:55 AM
B MAC's Avatar
B MAC
I am having the same issue, my SERVICE 4WD light blinks 3 times when I first start the truck but then goes away. My 4HI and 4LOW both just blink when I try to engage them. Tried in nuetral, tried going 4LO to 4HI tried at a low speed I basically tried everything, but still nothing. It feels like it is locking in and sounds that way but the light just blinks!
