adding a switch next to tow/haul etc...
Old Dec 20, 2009 | 12:44 PM
crod's Avatar
crod
Default adding a switch next to tow/haul etc...
hey guys. ive been thinking about getting the recon backup lights. my truck is a 4x4 quad cab sport. its not fully loaded, so no heated seats etc. since i dont have that button, is it a knock out? could i put a switch in their? i want a somewhat "factory" look. any ideas??
thanks.
Old Dec 20, 2009 | 04:47 PM
72combo's Avatar
72combo
That section that says ram comes out with 2 screws from behind you could probably buy the switches that go there and replace that spot you can alway paint it black put a clear with white printing ???? Just a thought
Old Dec 20, 2009 | 04:58 PM
crod's Avatar
crod
is that spot that says ram, where the heated seat buttons would go if i had the option?
Old Dec 20, 2009 | 05:03 PM
crod's Avatar
crod
ok, next idea. is their anyway to tie it into the cargo light switch?
so it ONLY comes on when you press it. not everytime the actual cargo light is activated. i.e. unlocking doors, etc....
that would be ideal. plus i can see the reflection of the cargo off my bed cover so it would remind me to turn it off..
Old Dec 20, 2009 | 10:43 PM
iRockCrawler's Avatar
iRockCrawler
What backup lights are you talking about from recon? if they are back up lights, why not tie into the backup lights on the truck???
Old Dec 21, 2009 | 09:08 AM
crod's Avatar
crod
http://www.gorecon.com/product.php?p...ights&p_cat=46
they go for about $70.00 sreet pricing..
well. i live in the burbs of detroit. heavy population. i prefer to be able to switch them on and off by myself. just to avoid harrasment by the cops etc.
Old Dec 21, 2009 | 10:13 AM
ilandaze2's Avatar
ilandaze2
use a relay and use the cargo light as the signal wire.
Old Dec 21, 2009 | 09:45 PM
usp45compact's Avatar
usp45compact
If the main purpose is for backing the truck up, I'd power them off the reverse lights, but have a switch in the loop to break or complete the circut when you do/don't want to use them. That way they generally come on and off aumoatically, but can be disabled when you desire.
Old Dec 21, 2009 | 10:05 PM
crod's Avatar
crod
i talked with a member on the forums here who is very familiar with all of the wiring projects etc.
i have since decided to run them off of a stand alone rocker switch. they will be powered by the battery, with an inline fuse.
i looked today, i feel comfortable putting the switch somewhere next to my power seat adjustments. its out of sight, not on the dash anywhere, and to most people will look somewhat factory....plus its easy to reach when sitting, without leaning one way or the other..
Old Dec 21, 2009 | 10:38 PM
GapRunr's Avatar
GapRunr
Are you going to use a relay? If you wire them direct to the battery, one day you will leave them on and forget about it, and when you get back to your truck the battery will be dead. A relay would prevent that from happening and also let you use a smaller switch without having to run the full current from the battery to the switch to the lights.
